Author Topic: ESP8266 NodeMCU flashing hangs at 10% problem (and fix)  (Read 3073 times)
Offline hamster_nzTopic starter
« on: July 23, 2016, 08:23:21 am »
This is being posted here many because I know it will get indexed, and others here  might be interested....
I was having problems with the first of 10 ESP8266 modules I've acquired from Deal Extreme - I couldn't flash new firmware (NodeMCU) as it would hang at 10%. Tried a whole lot of 'hints' found on the web (jumper this pin to that, hold mouth like so...) with no success.
Nor could I role back to stock firmware, as one of the four sections would fail to write (under both Linux and Windows). Tried different speeds and so on for a few hours...
Running an strace on the script showed it would just lock up after writing a whole lot of FF values - the ESP module would not reply.
So I then looked closer at the Usb/serial bridge (a cheap FT232RL based module). I wired it for loopback (TX jumpered to RX), and wrote the same data to the port - and the FT232RL locked up. Hummm...
I then got a trusted part (an FPGA dev board with a FTDI part on it) and tried the test program. It didn't lock up. So I pushed the RX and TX pins though the FPGA to a pin header, and tried flashing with the world's most expensive serial adapter... and bugger me, it worked.
I've got 10 fake serial adapters! :(
Just to prove it to myself I replaced the FT232RL with one I had on hand. It now flashes firmware perfectly.... Grrrrr
However, this means I now have a test that can detect these fakes - pretty much just send 10B of FF chars and see it it locks up!
The following users thanked this post: oPossum, kripton2035
Offline sporadic
    • forkineye.com
Re: ESP8266 NodeMCU flashing hangs at 10% problem (and fix)
« Reply #1 on: July 23, 2016, 10:19:26 am »
The ones based off the NodeMCU 1.0 design use the CP2102. I'd probably grab those for your next batch :) I try to stay away from anything FTDI now!
Sent from my XT1094 using Tapatalk
The following users thanked this post: ebclr
Offline ebclr
« Reply #2 on: July 24, 2016, 05:21:57 am »
It's very smart to avoid FTDI or you will be a semiconductor detective
Offline kripton2035
« Reply #3 on: July 24, 2016, 05:53:51 am »
a fake FTDI chip coming from deal extreme is not surprising at all...
like ebclr and sporadic, since the FDTI gate, I try to have other chips than FDTI like CP2102 or CHG340 not to search aftter buy if the chip is real or fake !
Offline firepower
  • Country: vn
« Reply #4 on: July 26, 2016, 11:22:25 pm »
Can you post pic of problem ESP8266 board so we know to avoid purchasing same.
« Reply #5 on: July 26, 2016, 11:40:57 pm »
It wasn't the ESP module, it was the USB to serial adapter.
http://www.dx.com/p/ftdi-basic-program-downloader-usb-to-ttl-ft232rl-for-arduino-389456
(image attached).
However I am sure that the same design is available with genuine chips on it, so the image doesn't help much.
Offline Kilrah
« Reply #7 on: July 27, 2016, 10:07:15 am »
Confirmed, I've got 3 identical-looking ones and they work fine so they must have genuine chips.
