Author Topic: ESP8266 - Ultimate DevBoard - Evolution  (Read 10510 times)
Offline TJ232Topic starter
  • www.esp8266-projects.org
    • ESP8266 Projects
« on: April 24, 2015, 11:32:35 am »
As you know, mostly of the existing ESP Boards are just some sort of breakout or breadboard adapters for ESP8266 Modules with or without a regulator on board.
Do you remember the CBDB story?
http://www.esp8266-projects.com/2015/02/esp8266-breadboard-time-cheap-and-dirty.html
Because of the big interest raised by the CBDB project, a fresh new DevBoard was born:
http://www.esp8266-projects.com/2015/04/esp8266-ultimate-devboard-finally.html
And because of the onboard capabilities I can call it a true IOT Development Board:
  • Easy AP/Client Wifi Access
  • Easy Firmware Programming
  • Easy Software Development
  • 18 bit ADC
  • 12 bit DAC
  • Voltage Measurement
  • Current Measurement
  • Temperature Measurement
  • Real Time Clock
  • High Resolution LCD COG Display with direct sunlight reading
  • User Definable Buttons
  • On Board 3.3V Regulator
How many of you were dreaming about something like that in your Uni labs even 10 years ago? :)
Waiting your thoughs about ;)
ESP8266 Projects - www.esp8266-projects.org
MPDMv4 Dimmer Board available on Tindie: https://www.tindie.com/stores/next_evo1/
    • ESP8266 Projects
Re: ESP8266 - Ultimate DevBoard - Evolution
« Reply #1 on: April 27, 2015, 12:59:50 pm »
Part 2 of the the new CBDBv2 Evolution Series (http://www.esp8266-projects.com/2015/04/esp8266-ultimate-devboard-finally.html)
This time we will take a look at the firmware programming process options and running our first test programm on this new Board.
Manual Programming with jumper select:
https://www.youtube.com/embed/ZUac5IsE-y8
Automated process with RTS/DTR lines for auto RST/bootloading:
https://www.youtube.com/embed/l2hYLFU32Yc
For more details about this project:
http://www.esp8266-projects.com/2015/04/p2-esp8266-ultimate-devboard-firmware.html
    • ESP8266 Projects
« Reply #2 on: April 28, 2015, 12:07:56 pm »
An example of Arduino IDE Setup for direct programming and firmware uploading on the new ESP8266 CBDBv2 Evolution DevBoard.  No user intevention needed,  no buttons to press :)
    • ESP8266 Projects
« Reply #3 on: May 05, 2015, 08:43:51 am »
What other functions to you think will be "nice-to-have" as expansion boards for CBDBv2 Evo Board?
Just added, because of high requrests, the MAINS Power Dimmer/Switch Module
What functions to you think is better to remove/replace from the main board?
Where is the point where you consider to many functions means less flexibility? Please keep in mind the Board was designed as a Development Board/Learning Tool and the integrated features are below:
    18 bit ADC
    12 bit DAC
    Voltage Measurement
    Current Measurement
    Real Time Clock
    I2C LCD Display interface
I am really looking forward to hear your oppinions about. Thank you.
Offline firepower
  • Country: vn
« Reply #4 on: June 17, 2015, 01:27:13 pm »
Do you have a component list or github folder for CBDBv2? And other PCB designs on your blog?
I noticed on schematic and pcb there are no no component values, only component ID's
Like your blog, lots of info.  :-+
    • ESP8266 Projects
« Reply #5 on: June 18, 2015, 06:53:46 am »
Thank you :)
Lots of things happened lately but as soon as possible a BOM list will be available.
Still tweaking on it and didn't had the chance to finalise a decent looking blog printable BOM.
If you look on the schematic, for a quick one just use:
- resistors - 10k, except led, voltage divider,current shunt.
- decoupling caps 100n,
- pol caps as 10u/100u.
CBDBv2 description List it's giving you also details about each function available.
If you want a PCB for experimenting they are directly available at our preferred PCB House, Dirty PCBs:
  http://dirtypcbs.com/view.php?share=5876&accesskey=3d0fd70d53d6dc20c0bf0255f67cde65
Offline Yansi
« Reply #6 on: June 18, 2015, 08:14:44 pm »
The schematic of that thing is drawn so ugly I wouldn't touch that thing. Blargh... (Just statement of a fact)
http://3.bp.blogspot.com/-M3X1OJgEePo/VToOF-huZ1I/AAAAAAAAAlY/Y9hbKKmBr9E/s1600/000%2B-%2BCBDBv2%2B-%2BSchematic%2B-%2B000.jpg
Offline firepower
  • Country: vn
« Reply #7 on: June 20, 2015, 11:27:36 am »
That is not statement of fact, that is just your opinion, and offensive.
People are taking the time to document and share their projects and knowledge for free, I appreciate that and accept that not everyone has the knowledge or time to produce professional standard diagrams.
As long as it is drawn accurately and works that's all that's need.
« Last Edit: June 20, 2015, 11:29:40 am by firepower »
Offline nctnico
« Reply #8 on: June 20, 2015, 11:33:00 am »
IMHO the ESP8266 is a mighty interesting module. I ordered a few just to play around with it.
The schematics are very bad indeed. Don't try to cram everything together on one page. I know it is free but if you want to make it easy for people to use your work put some time into a nice and easy to understand schematic otherwise it's just a waste of your time.
Offline Muxr
« Reply #9 on: June 20, 2015, 04:43:53 pm »
I really like esp8266. So far my favourite module is esp-12 sold by Alice. It has all the right breakouts and they even provide dimensions for PCB integrations:
http://www.ebay.com/itm/400909683102?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Offline schimmi2
« Reply #10 on: October 20, 2016, 01:50:21 pm »
Hello
I just wamted to find out the SOT23-6 Device U1 on the CDDB v2.0b Board near the SELDAC Jumper. I cant find it in the Circuit Diagramm
Thank You
    • ESP8266 Projects
« Reply #11 on: October 25, 2016, 05:08:30 am »
   Sorry for delay, a nasty cold put me "out-of-the-grid" for few days.
   CBDBv2 bord was designed as a educational platform to be used for many tutorials and experiments hence the different and sometime redundand functions that you might find onboard.
   Regarding U1 and the SELADC 3 way jumper, both can be used (not in the same time but as an option) for the same function, switching ADC input between Voltage and Current measurement.
U1 is a SPDT analog switch IC, you can use there a low ON-state resistance one with the break-before-make feature, like TS5A3159.
 Few working examples:
- U1 usage - do autoswitching between Voltage and Current measurements using internal ADC .
- 3 pin SELADC :
     - manual select Voltage/Current cource for internal ADC
     - choose to connect one source to the internal ADC by jumper and also can go with a second jumper wire to the high precision onboard ADC for example.
The schematics on my blog are accurate but might not include all these functions as quite a few versions released. Will do my best to keep it update (and insanely ugly, lol) but been busy as hell with a lot of things lately.
Happy breadboarding,
TJ.
PS: apparently I am wasting my time posting all these stuff but you know what: I really enjoy it.
