hi guys
Discrete Hartley transform is an analogue of discrete Fourier transform for real data, but it takes ONLY a real sequence as an input.
Do you happen to have on hand a good good implementation in C ?
I have to port it to different machines
thank you in advance
Googling "FHT in C" get you some code, but if you are concerned about the highest speed you might need something more tailored to the qualities of your platform. Depending how you implement things, the FHT may actually be slower than a well tuned FFT.
Taking a quick search on the web, could find something.
A "working" implementation of the FHT in C:
Not sure how usabe are the pseudo c-codes, anyway...
"happen to have on hand" should mean: do you
already have (at least have seen) a pretty chunk of
tested good C implementation ?
google doesn't tell you about that, google just reports whatever comes into the search key (which means, up to the 90% is … useless)
and I have no time, at least not now, to implement/test/check things
I am late, deadline coming, because my job-colleagues haven't done their homework
thank you the same
If you are in a hurry then you most likely best off using an implementation of the FFT where you most likely will be able to find a fast generic implementation or specific optimized versions for your particular hardware. You can calculate the Hartley transform from a FFT. Note that the memory requirement of the FFT is twice as high, though.
Even if you do find an implementation of the Fast Hartley Transform that suits you, you will need to verfify that it works and then you'll need a method based on the FFT.
A well optimized FFT implementation is equally as fast as the FHT, even with purely real inputs. There are optimization tricks you can do so that the complex computation is not wasted. I don't remember exactly how, though, but I know there is literature out there about it.
There are ways to use a normal FFT for real Fourier transform as well, you can efficiently do two transforms at the same time or do a 2N point real transform with a N point FFT.
TI has a lot of code (which I did use, around 2 decades ago).
thank you, guys, at the end of the week (friday and saturday, a few days ago), I have git-pulled a cool FFT implementation
I have recycled my old code, and spent my time trying to optimize and adapt it: luckily with great results at the end
this, after I explained to my colleagues that FFT is as fast as the Fast Hartley Transform
thank you to have pointed it out
