Author Topic: Flash memory corruption  (Read 5085 times)
Offline Richard HeadTopic starter
« on: February 26, 2014, 09:48:53 am »
Is it normal for the flash memory to occasionally get corrupted on power-up?
I have found this with an MSP430 device as well as a PIC. If I slow down the dV/dt on power-up it seems to help on the PIC.
Dick
Offline dannyf
Re: Flash memory corruption
« Reply #1 on: February 26, 2014, 12:25:52 pm »
I have never found it to be an issue.
On the flip side, I have experienced eeprom wearing out, but only in an endurance test environment.
« Reply #2 on: February 26, 2014, 01:10:54 pm »
Ok, after reading that I'm worried.
I never realised that it was such a common problem.
In my application the micro doesn't get powered down often, luckily.
There are a couple of 2.2uF tantalums across the rails, as well as a 100nF ceramic or two.
Dick
Offline amyk
« Reply #3 on: February 26, 2014, 01:20:58 pm »
Haven't had this happen on various 8051s, AVRs, and PICs when they're used in an application where the flash is read-only. It probably depends on the specific model, but flash getting corrupted even when it's not being written to (I can understand if a write operation was happening) is a little disturbing.
Offline dannyf
« Reply #4 on: February 26, 2014, 01:28:03 pm »
I wouldn't worry much about it.
Putting aside design issues and chip issues, flash corruption isn't a big issue, even in high reliability applications (medical for example). RAM corruption is usually where you are more concerned about.
There are cases where an application gets wiped out: most notably in pickit2/3 and some jlink clones. But those are design issues with the particular hardware.
« Reply #5 on: February 27, 2014, 02:05:53 pm »
Mojo-chan
Thanks for the feedback. I don't know whether brown-out detection has been enabled or not. I'll look into it.
I was also wondering if I could simply connect a 1K resistor between Vcc and GND to ensure that the supply dropped reasonably quickly following a power down condition. Luckily low power consumption is not a factor in this application.
Dick
