Author Topic: Float Counter  (Read 1310 times)
Offline george.manson.69Topic starter
  • Country: mx
Float Counter
« on: July 25, 2020, 05:18:18 pm »
Hello Everyone,
I have some problems, I have been doing a code to show a float number in a 4 digits of 7 segments,
for example,
I have a number 0.123, so in the display must show each number in display [0.][1][2][3]
but I put a printf function to show what happens to each number, and i got this.
0,0,12,123
of course in the display shows nothing correct.
This is a part of the code to convert to float to array number for the 4 digits.
(I use a PIC16F18877 in MPLAB X IDE with XC8)
#include "mcc_generated_files/mcc.h"
0011 1111 -> 0
0000 0110 -> 1
0101 1011 -> 2
0100 1111 -> 3
0110 0110 -> 4
0110 1101 -> 5
0111 1101 -> 6
0000 0111 -> 7
0111 1111 -> 8
0110 1111 -> 9
const uint8_t pattern[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
uint8_t mask = 0;
uint8_t* buffer[4];
uint8_t number[4];
float cont;
void shift_data(uint8_t data){
    RCLK_SetHigh();
    for(uint8_t i=0;i<8;i++){
        PORTDbits.RD1 = (data << i) & 0x80?1:0;
        SRCLK_SetHigh();    //Clock
        SRCLK_SetLow();
    RCLK_SetLow();
void converter_uint_to_array(uint16_t dataToConvert,uint8_t* buff){
    uint8_t mm,cc,dd,uu;
    PIE0bits.TMR0IE = 0;
    mm = (uint8_t)(dataToConvert / 1000);
    cc = (uint8_t)(dataToConvert / 100);
    cc = cc - ((uint8_t)(cc/10))*10;
    dd = (uint8_t)(dataToConvert / 10);
    dd = dd - ((uint8_t)(dd/10))*10;
    uu = dataToConvert - ((uint8_t)(dataToConvert/10))*10;
    *buff++ = mm;
    *buff++ = cc;
    *buff++ = dd;
    *buff = uu;
    PIE0bits.TMR0IE = 1;
void converter_float_to_array(float dataToConvert,uint8_t* buff){
    uint16_t d1,d2,d3,d4,aux = 0;
    if(dataToConvert>= 0.000 && dataToConvert < 10.00){
        d1 = (uint16_t)(dataToConvert);
        d2 = (uint16_t)((float)(dataToConvert - (float)d1));
        d3 = (uint16_t)dataToConvert*10;
        d3 = (uint16_t)(10*((float)(((float)dataToConvert*10) - (float)d3)));
        d4 = (uint16_t)dataToConvert*100;
        d4 = (uint16_t)(10*((float)(((float)dataToConvert*100) - (float)d4)));
        printf("4 %u,%u,%u,%u\r\n",d1,d2,d3,d4);
    }else if(dataToConvert>= 10.00 && dataToConvert < 100.0){
        d1 = (uint16_t)(dataToConvert / 10);
        d1 = d1 - ((uint16_t)(d1/10))*10;
        d2 = (uint16_t)(dataToConvert - ((uint16_t)(dataToConvert/10))*10);
        d3 = (uint16_t)dataToConvert;
        d3 = (uint16_t)((float)((float)dataToConvert - (float)d3) * 10);
        d4 = (uint16_t)dataToConvert*10;
        d4 = (uint16_t)((float)((float)(dataToConvert*10) - (float)d3) * 10);
        printf("2 %u,%u,%u,%u%\r\n",d1,d2,d3,d4);
    *buff++ = (uint8_t)d1;
    *buff++ = (uint8_t)d2;
    *buff++ = (uint8_t)d3;
    *buff = (uint8_t)d4;
                         Main application
void main(void)
    // initialize the device
    SYSTEM_Initialize();
    // When using interrupts, you need to set the Global and Peripheral Interrupt Enable bits
    // Use the following macros to:
    // Enable the Global Interrupts
    INTERRUPT_GlobalInterruptEnable();
    // Enable the Peripheral Interrupts
    INTERRUPT_PeripheralInterruptEnable();
    // Disable the Global Interrupts
    //INTERRUPT_GlobalInterruptDisable();
    // Disable the Peripheral Interrupts
    //INTERRUPT_PeripheralInterruptDisable();
    LATD = 0x00;
    number[0] = 0;
    number[1] = 0;
    number[2] = 0;
    number[3] = 0;
    buffer[0] = &number[0];
    buffer[1] = &number[1];
    buffer[2] = &number[2];
    buffer[3] = &number[3];
    while (1)
        converter_float_to_array(0.123,&number);
        __delay_ms(500);
        // Add your application code
I tried many times to resolve this issue if you have any idea that could help me, will be great!
regards!
Offline Nominal Animal
Re: Float Counter
« Reply #1 on: July 25, 2020, 09:50:49 pm »
Why are you using float on an 8-bit microcontroller without hardware float support?  Using e.g. int32_t to describe the values in thousandths (so 1 displays as 0.001 and -1 displays as -.001) would be just as precise, but much faster.
Here's what I'd use:
#include <stdint.h>
#define  display_none 0x00
#define  display_dot  0x80
#define  display_neg  0x40
#define  display_over 0x5C
static const uint8_t  display_digit[10] = {
    0x3F, /* "0": 0011 1111 */
    0x06, /* "1": 0000 0110 */
    0x5B, /* "2": 0101 1011 */
    0x4F, /* "3": 0100 1111 */
    0x66, /* "4", 0110 0110 */
    0x6D, /* "5", 0110 1101 */
    0x7D, /* "6", 0111 1101 */
    0x07, /* "7", 0000 0111 */
    0x7F, /* "8", 0111 1111 */
    0x6F, /* "9", 0110 1111 */
/* [0] is rightmost, [3] leftmost */
uint8_t  display_pattern[4];
void display_thousandths(int32_t  value)
    uint_fast32_t  u, v;
    int_fast8_t    i, s, d;
    display_pattern[0] = display_none;
    display_pattern[1] = display_none;
    display_pattern[2] = display_none;
    display_pattern[3] = display_none;
    if (value >= 9999500) {
        /* Too large to display. */
        display_pattern[2] = display_over;
        return;
    } else
    if (value >= 1000000) {
        u = (value + 500) / 1000;
        s = 0;
        d = 0;
    } else
    if (value >= 100000) {
        u = (value + 50) / 100;
        s = 0;
        d = 1;
    } else
    if (value >= 10000) {
        u = (value + 5) / 10;
        s = 0;
        d = 2;
    } else
    if (value > 0) {
        u = value;
        s = 0;
        d = 3;
    } else
    if (value == 0) {
        display_pattern[0] = display_digit[0];
        return;
    } else
    if (value <= -999500) {
        /* Too large to display */
        display_pattern[3] = display_neg;
        return;
    } else
    if (value <= -100000) {
        u = (500 - value) / 1000;
        s = 1;
        d = 0;
    } else
    if (value <= -10000) {
        u = (50 - value) / 100;
        s = 1;
        d = 1;
    } else
    if (value <= -1000) {
        u = (5 - value) / 10;
        s = 1;
        d = 2;
    } else {
        u = (-value);
        s = 1;
        d = 3;
    /* Optional: Remove trailing fractional zeros. */
    while (d > 1 && !(u % 10)) {
        u /= 10;
        d--;
    /* Save the value. We'll need it later. */
    v = u;
    /* Convert to digit patterns. */
    i = 0;
    do {
        display_pattern[i++] = display_digit[u % 10];
        u /= 10;
    } while (u > 0);
    /* Zeros up to decimal point. */
    while (i < d) {
        display_pattern[i++] = display_digit[0];
    /* Room for an unit zero? Need one? */
    if (d > 0 && s + i < 4) {
        if ((d == 1 && v < 10) ||
            (d == 2 && v < 100) ||
            (d == 3 && v < 1000)) {
    /* Negative? */
    if (s && i < 4) {
        display_pattern[i] = display_neg;
    /* Decimal point? */
    if (d > 0) {
        display_pattern[d] |= display_dot;
     * TODO: Update display based on display_pattern[].
and in your case, you can use the following to display floats via using the above:
void display_float(float value)
    if (value > 9999.999f)
        display_thousandths(9999999);
    else
    if (value >= 0.0f)
        display_thousandths((int32_t)(1000.0f * value + 0.5f));
    else
    if (value < -999.999f)
        display_thousandths(-999999);
    else
        display_thousandths((int32_t)(1000.0f * value - 0.5f));
Note that the 0.5f above are used for correct rounding.
If you want to explore what that looks like, add
#include <stdlib.h>
#include <stdio.h>
static const unsigned char lcd_mask[7][8] = {
    { 0x21, 0x01, 0x01, 0x01, 0x03, 0x00, 0x00, 0x00 },
    { 0x20, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00 },
    { 0x70, 0x40, 0x40, 0x40, 0x46, 0x00, 0x00, 0x00 },
    { 0x10, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00 },
    { 0x18, 0x08, 0x08, 0x08, 0x0C, 0x00, 0x80, 0x00 },
int main(int argc, char *argv[])
    float val;
    int   arg, r, c, d;
    char  dummy;
    for (arg = 1; arg < argc; arg++) {
        if (sscanf(argv[arg], " %f %c", &val, &dummy) != 1) {
            fprintf(stderr, "%s: Invalid value.\n", argv[arg]);
            return EXIT_FAILURE;
        } else {
            printf("%s:\n", argv[arg]);
            display_float(val);
            for (r = 0; r < 7; r++) {
                for (d = 3; d >= 0; d--) {
                    for (c = 0; c < 8; c++) {
                        if (display_pattern[d] & lcd_mask[r][c]) {
                            fputc('X', stdout);
                        } else {
                            fputc(' ', stdout);
                fputc('\n', stdout);
            fflush(stdout);
    return EXIT_SUCCESS;
so you can compile it on any C compiler, to be run on your development system.  Supply one or more numbers as a command-line parameter, and it'll display a crude ASCII version of the expected seven-segment display.  For example, for -99.25 it will print
        XXXXX   XXXXX   XXXXX
        X   X   X   X       X
        X   X   X   X       X
XXXXX   XXXXX   XXXXX   XXXXX
            X       X       X
            X       X       X
        XXXXX   XXXXX X XXXXX
and for 92.127
XXXXX   XXXXX       X   XXXXX
X   X       X       X       X
X   X       X       X       X
XXXXX   XXXXX       X   XXXXX
    X   X           X       X
    X   X           X       X
XXXXX   XXXXX X     X   XXXXX
The displayable range is -999 to 9999.  The code is smart enough to format -0.001 as -.001, but will use a leading zero if one fits.
  • Country: mx
Re: Float Counter
« Reply #2 on: July 26, 2020, 03:41:24 am »
Excellent, I'm going to use it and will tell you the results!,
Thanks!
