Author Topic: FMD IDE (fremont micro devices) i can't find and download it  (Read 24435 times)
Offline DavidAlfa
Re: FMD IDE (fremont micro devices) i can't find and download it
« Reply #25 on: August 14, 2024, 07:36:57 am »
Link works for me!
Offline manish12
  • Country: in
« Reply #26 on: August 16, 2024, 02:02:45 am »
Mega.nz Website not Loading, Timeout Solution
Solution
Configure your network settings to use the IP addresses 8.8.8.8 and 8.8.4.4 as your DNS servers.
Step 1 Go to Network connection Properties
Step 2 Enter the values
Preffered DNS Server = 8.8.8.8
Alternate DNS Server =8.8.4.4
Click Ok.
[Issue Resolved]
Offline ass20
« Reply #27 on: August 17, 2024, 09:31:08 am »
Hi
 what is hardware need for flash FMD 8 bit cpu ?
Offline zezo2030
  • Country: jo
« Reply #28 on: May 01, 2025, 11:30:02 pm »
Hello can you share the latest available fmd ide again?
thank you
Offline DavidAlfa
Offline zezo2030
  • Country: jo
« Reply #30 on: May 02, 2025, 02:44:47 pm »
Thank you ,its working well.
but how to generate the .hex file??can not find the . hex file in the compiled project....
also can you share the fmd mcu_writer software?? the writer is v2.5 ..
thank you
Offline DavidAlfa
« Reply #31 on: May 04, 2025, 12:28:09 pm »
I had v3.1.1.3 in my local drive (Original post), which included FMD Programmer:
1_CompilerSetup2.0.3.exe
2_FMDIDE_Setup_V3.1.1.3.exe
3_FMDProgrammer_Setup_V5.3.6.5.exe
4_VisualTouchTL_Setup_V2.0.3.1.exe
Google Drive Download
« Last Edit: May 04, 2025, 12:32:59 pm by DavidAlfa »
Offline Alarus
  • Country: ru
« Reply #32 on: May 08, 2025, 03:15:11 am »
I found a more recent version of the FMD IDE.
1_CompilerSetup2.0.6.exe
2_FMDIDE_Setup_V3.1.1.8.exe
3_FMDProgrammer_Setup_V5.3.9.0.exe
4_VisualTouchTL_Setup_V2.0.3.7.exe
5_FMD_IAP_V2.5.exe
« Last Edit: February 17, 2026, 03:11:49 pm by Alarus »
The following users thanked this post: n.kolev
Offline Buriedcode
« Reply #33 on: February 23, 2026, 10:27:34 pm »
Cleaning up root folder name from chinese symbols helps.
Finally got round to testing the IDE - after knocking up a programming adapter with the CH341(B).   Tried example projects, and got the following compiler error:
(669) prefix list matched more than one SDB type
grinux was correct - any chinese symnbols in the directories screws this up - once moved to another directory, compiled just fine  :-+
Offline n.kolev
  • Country: bg
  • Lab 82
« Reply #34 on: July 27, 2026, 07:37:26 am »
5_FMD_IAP_V2.5.exe
Большое спасибо — желаю вам здоровья!
