Yes, IMHO, the new system totally sucks. The amount of traffic wasn't high, it was even on the low side, and in most cases the subjects are now relevant for multiple new subforums. Is "ARM" meant for discussing the ARM core exclusively, or is it a catch-all for all other ARM microcontrollers except STM32, which has its own section?
In reality, ARM microcontrollers have a lot more in common than not - libraries, compilers, workflows, everything except on-chip peripherals.
Arduino is embedded computing? What
? This is horribly miscategorized. I'm not sad to see Arduino topics disappearing from my view, was never interested, but anyway, it's just plainly and utterly wrong. It's as far from "embedded computing" as it can get. Arduino
if anything is a textbook example of a classical embedded microcontroller system, simply a devboard for a microcontroller, and the architecture is
specifically designed to perform IO control of physical devices like LEDs, motors, etc., and totally suck on computing, which no one uses it for, for obvious reasons. I don't know if we need a division between MCUs and computing, but if we do, Arduino's on the wrong side.
I don't know how others read this forum, but I open up the interesting sections in tabs, look for new interesting topics, and participate. I used to open 3-5 sections, now I would need to open more than 10, most of which now have 0 new posts most of the time (or 1 new post, which is unlikely to be interesting).
In the old system, even after a week or two of absence, the new topics fit within half a page, easy to cherry-pick.
But I understand it's not my forum, the owners are welcome to do whatever they want, but IMHO this was clearly a very whimsical way to break the existing, working, well balanced structure, which still had enough future-proofing for increasing number of posts, at least for 2x or 3x.
If it's just a test, well, it's clearly not working for me at all and I can see myself stopping contributing to the microcontroller/FPGA section due to this extra complication. In any case, please, whatever you do, please don't spread this cancer to the "Projects, Designs, and Technical Stuff" forum, it's working like a charm as it is.
If you
really need to divide, do the division lines where they naturally exist. MCU and FPGA have very little to do with each other, so consider separating them (now you missed this obvious thing, and you don't have any forum anymore for Lattice FPGA's, for example!), and if you
really need to separate the Arduino stuff, make it some kind of an "MCUs for beginners" or "adafruit module engineering" section. We are not seeing a lot of these topics here, which signifies two things; 1) this is clearly a forum for professional, experienced EE's, 2) such forums exist elsewhere and serve their audiences well.
Please also note that the actual front page that lists the forums fails to list the descriptions for the child forums, and as they are insufficiently named, you are bound to see people failing to understand the categorization. What's "Intel"? Intel processors? Intel microcontrollers? Nope! It's Intel FPGA's, but you can't know it from where you'd normally open the categories.
