It's a very powerful combination.
I do a lot of designs in which a microcontroller takes care of the high level functions of the product, and an FPGA performs functions which are time critical, or which would result in a lot of data which might use a lot of CPU time to process.
For example, suppose you want to generate a signal, then digitise the response of a system to that signal. Something needs to drive the ADC, at exactly the right time and at exactly the right speed, capture the results, then perform some pre-processing such as averaging, filtering, multiply-accumulate operations and so on. The amount of data which the CPU ever has to deal with can be dramatically less than it would be otherwise, if you have an FPGA to do the repetitive operations.
Putting these functions into the FPGA also means that, while all this is happening, the CPU can be talking to the outside world, processing commands, talking on a serial bus, updating statistics or whatever.
I've also used FPGAs to implement interfaces that are uncommon, or perhaps not available in sufficient quantity in an off-the-shelf CPU. Need to build an interface card with 32 serial ports, all of which are active simultaneously? No problem: write one in VHDL, instantiate it 32 times in your FPGA, and use a high speed interface between the FPGA and your CPU.
