Author Topic: Gal-s  (Read 2496 times)
Offline DajgoroTopic starter
  • Country: hr
    • hackaday.io
Gal-s
« on: July 01, 2014, 07:29:43 pm »
Hi.
I have a few gals in my box, and since they can come handy for some small projects I would like to have a way to load those arrays with some logic.
Back at uni I had to use Palasm, but that works only in MS-DOS, and I need a dos box for that.
Is there any sw that is not completely archaic that works on win7?
Offline janoc
Re: Gal-s
« Reply #1 on: July 01, 2014, 08:11:57 pm »
I think Atmel still has WinCUPL available somewhere.
http://www.atmel.com/tools/WINCUPL.aspx
Offline Precipice
Re: Gal-s
« Reply #2 on: July 01, 2014, 08:22:21 pm »
Does your PAL programmer work on a modern machine?
I just compile my PALs and other ancient stuff on the same win95 laptop that I keep around to run the ancient programmers...
(I know this isn't an answer to your question, but laptops this ancient are often free...)
  • Country: hr
    • hackaday.io
Re: Gal-s
« Reply #3 on: July 01, 2014, 09:06:12 pm »
I downloaded it and it seems to work.
I do have a programmer capable of writing to gals, now I only need to figure out how to get the compiled code to the chip.
Edit: Found it, the jedec compiled jed file is in the same folder as the pld file.
« Last Edit: July 01, 2014, 09:12:06 pm by Dajgoro »
