Author Topic: gcc errors  (Read 4424 times)
Offline legacyTopic starter
gcc errors
« on: August 02, 2019, 10:05:32 am »
I am trying to recompile gcc-v2.95 with gcc-8.3.0, and ... I see errors like this:
# define obstack_ptr_grow(OBSTACK,datum)                                \
__extension__                                                           \
({ struct obstack *__o = (OBSTACK);                                     \
   if (__o->next_free + sizeof (void *) > __o->chunk_limit)             \
     _obstack_newchunk (__o, sizeof (void *));                          \
   *((void **)__o->next_free)++ = ((void *)datum);                      \
   (void) 0; })
../../../src/gcc-2.95.3/gcc/../include/obstack.h:420:30: error: lvalue required as increment operand
how would you fix this? (there are 219 similar lines  :palm: )
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
If one can make knowledge flow than it will go from negative to positve , for real
  • Country: pt
  • Kernel Panic
    • Malagas Lair
Re: gcc errors
« Reply #3 on: August 02, 2019, 10:57:51 am »
Here is a newer version for that particular file obstack.h in binutils-gdb when comparing with the stackoverflow
 links which  are older
https://github.com/redox-os/binutils-gdb/blob/master/include/obstack.h
They've re-arranged in splitted macros.
Re: gcc errors
« Reply #4 on: August 02, 2019, 01:10:40 pm »
Thanks! That file has just made my day since it has fixed the main problem!
gcc-2.95.* has a lot of other minor problems, but I have fixed them, and I have just compiled the crosscompier for the m88k (eight eight key) target
  target: m88k-coff
binutils: 2.12
     gcc: 2.95.3
    libc:
    path: /idp/bin/m88k-coff-*
NewOrangeBox # m88k-coff-gcc -v
Reading specs from /idp/lib/gcc-lib/m88k-coff/2.95.3/specs
gcc version 2.95.3 20010315 (release)
Offline SiliconWizard
Re: gcc errors
« Reply #5 on: August 02, 2019, 01:41:46 pm »
Yeah, apparently old GCC code was relying on non-standard rules to compile.
GCC 2.95 code base was all written BEFORE C99 came out, and anyway, GCC was not conforming to the standard as well as it does now either...
Now I'm wondering whether a typical (non GCC) C compiler of the time (~1999) would compile this (I kinda doubt it, although some old C compilers would treat void * kinda as char * ?), or if the above code would only compile with GCC itself, requiring some bootstrapping.
Offline NorthGuy
Re: gcc errors
« Reply #6 on: August 02, 2019, 03:42:15 pm »
It shouldn't. The C99 standard says:
"Except when it is the operand of the sizeof operator, the _Alignof operator, the
unary & operator, the++operator, the--operator, or the left operand of the. operator
or an assignment operator, an lvalue that does not have array type is converted to the
value stored in the designated object (and is no longer an lvalue)" (6.3.2.1.2)
So you shouldn't be able to cast to void** before ++.
The compliant way is to add sizeof(void*) to it instead of casting and incrementing, just as they do few lines earlier.
Re: gcc errors
« Reply #7 on: August 02, 2019, 03:56:24 pm »
I know it shouldn't in C99. You probably didn't quite get what I meant.
Most C compilers in 1999 were NOT compliant with C99 (and it took a few years before reasonably compliant compilers came out), and GCC either IMO (or maybe it had very partial compliance, dunno).
So my question was whether a typical C89/90-compliant compiler at the time would be able to compile this properly, or whether it was just relying on GCC's particular implementation.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
Re: gcc errors
« Reply #8 on: August 02, 2019, 04:50:02 pm »
Looks like it was a new feature implemented on the  GNU GCC 2.95 , whether it was able to compile with that option is dubious.
https://www.gnu.org/software/gcc/gcc-2.95/features.html
