Based on what I learned in searching for the right parts and putting things together, I started playing around with mosfets, inductors and capacitors themselves to conceptually build something. I thought of many setups like solar - boost - ultracap - boost - µc setup with a bypass over the ultracap etc etc. After some shetching and reoganizing, something came up that might do the trick. I choose to minimize the amount of bulky components like inductors (using just one) and use mosfets instead to route the energy flows around, so there are a couple of those in use as HSPDS (high side power distribution switches).
Being curious if it could work, the search shifted to find a way to drive the mosfets. The thing is that there are quite some, minimum 10, preferable 12, 16 would give some breathing space for expansion would that be needed. Almost all of them must be able to do PWM, however not all at the same time. I think 3, maybe 4 would be enough. And between the active PWM signals, different duty cycle and phase shifting is needed.
As I know a thing or 2 about AVR microcontrollers, I started looking at GPIO PWM expanders like the interesting PCA9685. Its output frequency is limited to 1526Kz, making it useless for this application.
Inline edit: PCB.Wiz mentions higher output freq, so I will definitely have another look there. As already partly replied, other expanders (mostly LED drivers) seem to only have open drain outputs, which probably would require an additional mosfet driver to be able to switch fast enough while keeping quiescent current low, and don't have to phase shift the PWM signals eather.
Don't know much about FPGA's, but I think I might have to look there to have the needed flexibility. Before jet another deep dive in searching, I thought it might be a good thing just asking. If FPGA's are a good choise, which I don't know at the moment, maybe some advise on where to start with them?
Ah, btw also wanting some ADC's of coarse, think 8 will be ok I hope. That's unfortunately no feature creep... just me being a bit (too?) focused on the driving part... Its for measuring the internal voltages and some currents. Guessing 10bit should be ok. Sure there will be some additional requirements, but don't know those at the moment.
As already mentioned, thanks for the replies, need to have a siesta and digest the info.
