Author Topic: GNU ARM Eclipse is now available from Eclipse Marketplace  (Read 6475 times)
Offline ilgTopic starter
« on: December 09, 2015, 01:57:56 pm »
Overview
The GNU ARM Eclipse project includes a set of open source Eclipse plug-ins and tools to create/build/debug/manage ARM (32-bits) and AArch64 (64-bits) applications and static/shared libraries, using the latest GNU ARM GCC toolchains.
Eclipse Marketplace
Aiming to further improve the user experience while installing/updating the plug-ins, the GNU ARM Eclipse project was registered to Eclipse Marketplace:
Benefits
The main advantage of using the Eclipse Marketplace is a simplified install procedure, no longer requiring to manually enter the update site address.
The Install button
The Eclipse Marketplace not only provides a centralised index to locate projects, it goes one step further and provides a drag-and-drop browser button.
As seen above, the button can be included in any web page.
To use it, just drag-and-drop the button to a running Eclipse, and the plug-ins to install/update will be automatically identified:
If, for any reason, this does not work, it is always possible to search the Eclipse Marketplace manually from within Eclipse menus:
More info
For more details about the GNU ARM Eclipse project, please refer to the project site http://gnuarmeclipse.github.io/.
Offline Brutte
Re: GNU ARM Eclipse is now available from Eclipse Marketplace
« Reply #1 on: December 09, 2015, 07:44:59 pm »
Well, I never had any problems with installation of your wonderful plug-in or packs (huge thanks!) even though several clicks were needed. Now with marketplace integration that would be even closer to one-click-to-install IDE for ARMs (like with commercial IDEs).
What is next? Wizarding?
I'd love to have the uVision-compatible configuration wizard annotations.
« Reply #2 on: December 09, 2015, 08:07:10 pm »
a future version this might bring this too (please add a new enhancement request in GitHub Issues to be sure I don't forget about it), but before this a new wizard to create projects from packs will be implemented.
Online bson
« Reply #3 on: December 14, 2015, 12:41:03 am »
Including support for OpenOCD?  The whole edit-compile-program-debug cycle?  If so, nice!!!
« Reply #4 on: December 14, 2015, 08:27:10 am »
yes, the whole cycle, with debugging support, ready to run templates, emulator, and many more.
