Author Topic: HEDS-5500:: weird index?  (Read 1078 times)
Offline 0dbTopic starter
  • Country: zm
« on: June 07, 2020, 03:07:18 pm »
so a collegue gave me yesterday an ARM board (probably derived from Odrive?) which has the HEDS-5500 incremental encoder, and asked me to give an eye to it because apparently the firmware doesn't work correctly.
The first thing I did this mornign was attaching the incremental encoder to a LA, to have a look.
The HEDS-5500 has three signals
- channel A
- channel B
- index
The index output is a 90 electrical degree, high true index pulse which is generated once for each full rotation of the codewheel.
But ... look at the screenshot: the index signal is always equal to channel B ... I wonder why?!?
I have already tried two of these encoders. Always the same result.
« Last Edit: June 07, 2020, 03:09:00 pm by 0db »
Offline dmendesf
  • Country: br
Re: HEDS-5500:: weird index?
« Reply #1 on: June 07, 2020, 04:31:48 pm »
From the datasheet:
For the HEDS-5500 and HEDM-5500, Pin #2 is a No Connect.
For the HEDS-5540 and HEDM-5540, Pin #2 is CH. I, the index output
The following users thanked this post: 0db
  • Country: zm
« Reply #2 on: June 07, 2020, 04:46:14 pm »
No connect, but there is a signal on that pin #2. A copy of the channel B.
I think someone must have shipped the wrong couple of encoders with the kit.
Offline dmendesf
  • Country: br
« Reply #3 on: June 07, 2020, 08:34:21 pm »
Seems so. "No connect" isn't the same as "not connected"...
Offline H.O
« Reply #4 on: June 08, 2020, 08:33:33 am »
And you are sure the signal is actually there, it's not crosstalk between channels on the LA due to the index channel actually floating?
  • Country: zm
« Reply #5 on: June 08, 2020, 09:12:31 am »
Yes, it's really there, on the 4th channel of the LA. I see it even if I remove both the ChA and ChB of the encoder.
And since it's really there, this was the reason why the Odrive controller didn't work: because in autocalibration mode it assumed the encoder had an index, since the firmware actually saw some signal on the Pin#2.
