Author Topic: Help finding software and docs on a Development board with an EEPROM programmer  (Read 1651 times)
Offline StrahoTopic starter
  • Country: bg
Hey guys, I have found this last week in the local flea market. It has an Atmel AT89C52 8 bit micro and several sockets for I presume flashing different EEPROMs. The only thing that identifies it is a small label on the PCB that says MULTIPROG Rev. A. Does anybody know where i can find info on this thing .. I can only find info on the Atmel micro ...everything else is ungoogable - no information whatsoever ..... I need documentation and software. Would be glad if someone has info on this :)
thats the beast :)
https://photos.app.goo.gl/LlQYpi8SXKr1fOd62
Online Andy Watson
It clearly has a rs232 type serial connection - have you tried talking to ? It might identify itself.
It also has what looks like a second crystal in the middle of the cluster of programming sockets - I think this may be aimed at programming processors rather than EPROMs.
  • Country: bg
Thanks, I will follow the pinouts to determine a safe voltage and see if the thingie talks. Will post results when ready.
Offline amyk
A quick Google suggests it could be PLC related.
Offline funkathustra
There's a bazillion programmers like that out there. They're made by little outfits that come and go. I wouldn't be surprised if there was a lot of protocol re-use between models. The trick is to find models that obviously have an old 8051 MCU and an RS232 port. If they have USB, look for a USB-to-serial converter.
Maybe try:
http://www.electroons.com/blog/know-how-using-wilar-sp200s-enhanced-device-programmer/
https://www.makenation.co.uk/programmers/sp200s-eeprom-programmer-kit/
https://alselectro.wordpress.com/tag/universal-programmer/
http://www.nskelectronics.com/usb_8051_programmer.html
In my searching, the "Wilar Programmer" kept coming up, and I've verified the Wilar Programmer SP200S uses an 8052 MCU. Probably start  there!
Offline ebclr
My beat is that this is an EPROM programmer
