I know that all but (referring to a
alanb post) I was still hoping to be able to reprogram the damn thing because it's much easier to do that (if it's not locked) then to unsolder original mcu and solder back the replacement... Original source code is not so important because I don't like it anyway.
As for reverse engineering: MSP430G2230 from Texas Instruments has a compatible pinout (
datasheet, page 2), my friend (with same bike light) got one today, burned new UI to it and replaced original MCU with it, works better than the genuine MCU BUT, it's a pain in the "back" to do so and it can only be done once (soldering that thing is messy job), that's why I was hoping to discover what is the genuine MCU and I was hoping it's Attiny (something like 13a) only question in that case would be is it locked or not...
Cheers
P.S. P4T is right, chinese flashlights mostly use atmel atiny13a:
