Author Topic: Help with C code  (Read 2840 times)
Offline jeet55Topic starter
Help with C code
« on: April 22, 2021, 09:16:16 am »
so I want to register a callback which will be called whenever the DMA transfer is completed but I don't know how to register a callback I tried passing the function pointer but it's giving me errors. I am attaching the API below can someone please help me.
Online newbrain
Re: Help with C code
« Reply #1 on: April 22, 2021, 09:36:29 am »
Showing your code and the error you are getting would help us helping you...
In general: the callback, according to the picture you posted, must be declared as a function returning void and taking a pointer to DMA_HandleTypeDef parameter.
See a suitable declaration below:
void my_callback(DMA_HandleTypeDef *_hdma);
« Reply #2 on: April 22, 2021, 09:44:15 am »
and how do I pass it to register it?? should I just pass the function name?
Online newbrain
« Reply #3 on: April 22, 2021, 10:43:34 am »
Yes, either the function name or the function name preceded by & are fine, see paragraph 9 of chapter 6.6 Constant Expression in C11 standard:
An address constant is a [...], or a pointer to a function designator; it shall be created explicitly using
the unary & operator [].., or implicitly by the use of
an expression of array or function type.[...]
Offline DavidAlfa
« Reply #4 on: April 22, 2021, 04:48:13 pm »
Check the DMA callback IDs:
typedef enum
  HAL_DMA_XFER_CPLT_CB_ID         = 0x00U,  /*!< Full transfer     */
  HAL_DMA_XFER_HALFCPLT_CB_ID     = 0x01U,  /*!< Half Transfer     */
  HAL_DMA_XFER_M1CPLT_CB_ID       = 0x02U,  /*!< M1 Full Transfer  */
  HAL_DMA_XFER_M1HALFCPLT_CB_ID   = 0x03U,  /*!< M1 Half Transfer  */
  HAL_DMA_XFER_ERROR_CB_ID        = 0x04U,  /*!< Error             */
  HAL_DMA_XFER_ABORT_CB_ID        = 0x05U,  /*!< Abort             */
  HAL_DMA_XFER_ALL_CB_ID          = 0x06U   /*!< All               */
}HAL_DMA_CallbackIDTypeDef;
Given this:
    DMA_HandleTypeDef dma1;
    void myDMAcallback(DMA_HandleTypeDef* dma){
      asm("nop");                              // Whatever
Then register the callback:
    HAL_DMA_RegisterCallback(&dma1, HAL_DMA_XFER_CPLT_CB_ID, myDMAcallback);    // Register DMA transfer complete callback
That just does this:
dma1.XferCpltCallback = myDMAcallback;
It won't enable the DMA interrupt or anything else.
Check __HAL_DMA_ENABLE_IT
    __HAL_DMA_ENABLE_IT(&dma1, DMA_IT_TC);    // Enable Transfer complete interrupt.
And of course you need the DMA init code in first place.
« Last Edit: April 22, 2021, 05:01:28 pm by DavidAlfa »
