Author Topic: Help with code inverter microcontroller programming  (Read 1103 times)
Offline somar1Topic starter
« on: May 14, 2020, 12:25:46 am »
Hi
I have this circuit and it works great
This scheme on Proteus 8
The circuit are feed back from the Transformer
The transformer output coil is 400V and the tension is set to 220V by the variable resistance 100K
My experience is poor in programming the microcontrollers and I want your experiences in the programming code
https://www.mediafire.com/file/t1izzo2lmrdzakc/sin2.pdsprj/file
greetings to you all
