Hi everyone,
I'm trying to build a DC load as a project and I'm running into trouble when it comes to getting the STM32 G431RBT to talk to my ADS1256 ADC. I'm trying to write the drivers myself, utilizing the HAL, just to get some practice with embedded programming.
I have attached a github repo I have created for better viewing of the code, and it also contains screenshots of my oscilloscope and logic analyser.
I have a function (ADS1256_RegDump), which basically sends the RREG command (RREG, Start at address 0, read 11 registers), and then dumps the resultant data into an array (also screenshotted and in the repo). The reset values for the registers are noted in the datasheet, page 30, table 23. As you can see, the data I am receiving is actually close to the reset values, but some are just slightly off. I am aware of the T6 delay that needs to be observed and you can see the communication in the repo. Also when I read the data (CH0) I get some sort of insane reading that is not correct. I'm thinking it's some sort of issue with SPI, but I've tried all the modes (CPHA 1/2, CPOL) and the results get no better or worse.
I was wondering if anyone has experience with this IC, and can help me out? better still, if you have one available to you and can quickly set it up and send me readings from a logic analyser or a scope if you have the time, I would be incredibly grateful.
As you can see, on my scope screenshots, CH3 (MISO) has some funky things going on at the end of some of the packets, but not all, I'm not sure why this is? I can spot some crosstalk between the lines as I am currently using the nucleo dev board and a ADS dev board connected with some short jumpers, but the crosstalk doesn't look too bad (<.5Vpp).
Scope: CH1: SCK, CH2: MOSI, CH3: MISO, CH4:CS
https://github.com/BRoughley488/STM32-DC-Loadhttps://www.ti.com/lit/ds/symlink/ads1256.pdfAny help would be appreciated (Settings listed below).
(SPI 3 is used for the ADS1256, SPI2 is for a shift register / 7 seg display)
Frame: Motorola, 8 bits, MSB First
Prescaler: 64 (2.65625MBits/s) I know this is a bit over the datasheet, however the results do not change at 1.328125MBits/s which I usually run it at.
CPOL:Low
CPHA: 2 Edge
CRC: disabled, NSS: Software
Thanks in advance
