Author Topic: help with stm32 lcd libraries  (Read 938 times)
Offline vortexTopic starter
  • Country: ma
« on: December 10, 2023, 08:07:14 pm »
hi ihave this librarie thats work wtih stm32fxxx but when i try to use it with stm32g030 it give me error when compiling in this part of the code
i have uploder the librarie in attachments
i use plattformio CRL,  CRH  register is not used on stm32g i i tried my best and failed to figure the problem
iam still newb so someone help me please
#if(LCD_RST<8)
#define _rst_Out()   LCD_PORT->CRL &=~(0xF<<(4*LCD_RST));\
               LCD_PORT->CRL |= (0x3<<(4*LCD_RST));
#else
#define _rst_Out()   LCD_PORT->CRH &=~(0xF<<(4*LCD_RST));\
               LCD_PORT->CRH |= (0x3<<(4*LCD_RST));
#endif
#if(LCD_CS<8)
#define _cs_Out()   LCD_PORT->CRL &=~(0xF<<(4*LCD_CS));\
               LCD_PORT->CRL |= (0x3<<(4*LCD_CS));
#else
#define _cs_Out()   LCD_PORT->CRH &=~(0xF<<(4*LCD_CS));\
               LCD_PORT->CRH |= (0x3<<(4*LCD_CS));
#endif
#if(LCD_SDA<8)
#define _sda_Out()   LCD_PORT->CRL &=~(0xF<<(4*LCD_SDA));\
               LCD_PORT->CRL |= (0x3<<(4*LCD_SDA));
#define _sda_In()   LCD_PORT->CRL &=~(0xF<<(4*LCD_SDA));\
               LCD_PORT->CRL |= (0x8<<(4*LCD_SDA));
#else
#define _sda_Out()   LCD_PORT->CRH &=~(0xF<<(4*LCD_SDA));\
               LCD_PORT->CRH |= (0x3<<(4*LCD_SDA));
#define _sda_In()   LCD_PORT->CRH &=~(0xF<<(4*LCD_SDA));\
               LCD_PORT->CRH |= (0x8<<(4*LCD_SDA));
#endif
#if(LCD_CLK<8)
#define _clk_Out()   LCD_PORT->CRL &=~(0xF<<(4*LCD_CLK));\
               LCD_PORT->CRL |= (0x3<<(4*LCD_CLK));
#else
#define _clk_Out()   LCD_PORT->CRH &=~(0xF<<(4*LCD_CLK));\
               LCD_PORT->CRH |= (0x3<<(4*LCD_CLK));
#endif
#define _Init_GPIO() { _rst_Out(); _cs_Out(); _sda_Out(); _clk_Out();}
#endif
#endif /* NOKIA1661_HW_H_ */
Online DavidAlfa
Re: help with stm32 lcd libraries
« Reply #1 on: December 10, 2023, 10:57:32 pm »
Check STM32F10x RM008 page 171 and STM32FG0x0 RM0454 page 182.
The GPIO registers are different, so that function needs to be properly ported.
This is what original code does:
#if(LCD_RST<8)                                                               // CRL is for pins 0-7, CRH for pins 8-15
#define _rst_Out()   LCD_PORT->CRL &=~(0xF<<(4*LCD_RST));\                   // Clear all 4 bits in CNF / MODE
                     LCD_PORT->CRL |= (0x3<<(4*LCD_RST));                    // CNF=00 (General PP output mode), MODE=11 (Speed=50MHz)
#define _sda_In()   LCD_PORT->CRL &=~(0xF<<(4*LCD_SDA));\                    // Clear all 4 bits in CNF / MODE
                    LCD_PORT->CRL |= (0x8<<(4*LCD_SDA));                     // CNF=10 (Input with pull resistor enabled), MODER=00 (Input mode). Assume it's defaulting to pulldown?
#endif
So this is it.
Since all inputs/outputs are initialized with the same settings, we can simplify it a lot by adding higher macro levels and using CMSIS macros:
#define _out(P)     MODIFY_REG(LCD_PORT->MODER, 3<<(2*P), 1<<(2*P)); \      // Clear MODER bits, set MODER=01 (General output mode)
                    CLEAR_BIT(LCD_PORT->OTYPER, 1<<P); \                    // Clear OTYPER bit = output push-pull.
                    SET_BIT(LCD_PORT->OSPEEDR,  3<<(2*P))                   // Set OSPEEDR bits to 11 = max speed
#define _in(P)      CLEAR_BIT(LCD_PORT->MODER,  3<<(2*P)); \                // Clear MODER bits (Input mode)
                    MODIFY_REG(LCD_PORT->PUPDR, 3<<(2*P), 2<<(2*P))         // Enable pull-down
#define _rst_Out()  _out(LCD_RST)
#define _cs_Out()   _out(LCD_CS)
#define _sda_Out()  _out(LCD_SDA)
#define _sda_In()   _in(LCD_SDA)
#define _clk_Out()  _out(LCD_CLK)
Final file, note that I also replaced replace the include "stm32f10x.h" with "stm32g0xx.h".
 * nokia1661_Hw.h
 *  Created on: Sep 11, 2019
 *      Author: zeus
#ifndef NOKIA1661_HW_H_
#define NOKIA1661_HW_H_
#define LCD_AVR_HW 1
//#define LCD_STM_HW 1
#if defined(LCD_AVR_HW) && defined(LCD_STM_HW)
#error Only Select One Hardware AVR/STM
#endif
#if !defined(LCD_AVR_HW) && !defined(LCD_STM_HW)
#error You need to define Hardware Type for LCD usage
#endif
#ifdef LCD_AVR_HW
#define LCD_PORT PORTB
#define LCD_PIN PINB
#define LCD_DDR DDRB
#define LCD_RST PINB1
#define LCD_CS PINB2
#define LCD_SDA PINB3
#define LCD_CLK PINB5
#include <avr/io.h>
#include <util/delay.h>
#include <avr/pgmspace.h>
#define SBI(port,bit) asm("sbi %0, %1" : : "I" (_SFR_IO_ADDR(port)), "I" (bit))
#define CBI(port,bit) asm("cbi %0, %1" : : "I" (_SFR_IO_ADDR(port)), "I" (bit))
#define LCD_RSDA() (LCD_PIN&(1 << LCD_SDA))
#define LCD_GPIO_Enable()
#define _sda_In() LCD_DDR &=~(1<<LCD_SDA)
#define _sda_Out() LCD_DDR |= (1<<LCD_SDA)
#define _rst_set() SBI(LCD_PORT,LCD_RST)
#define _rst_clr() CBI(LCD_PORT,LCD_RST)
#define _cs_set() SBI(LCD_PORT,LCD_CS)
#define _cs_clr() CBI(LCD_PORT,LCD_CS)
#define _sda_set() SBI(LCD_PORT,LCD_SDA)
#define _sda_clr() CBI(LCD_PORT,LCD_SDA)
#define _clk_set() SBI(LCD_PORT,LCD_CLK)
#define _clk_clr() CBI(LCD_PORT,LCD_CLK)
#define _Init_GPIO() LCD_DDR |= (1 << LCD_RST) | (1 << LCD_CS) | (1 << LCD_SDA) | (1 << LCD_CLK)
#elif defined(LCD_STM_HW)
#include <stm32g0xx.h>
#include <string.h>
#define LCD_PORT GPIOA
#define LCD_GPIO_Enable() RCC->APB2ENR |= (1<<2)
#define LCD_RST 7
#define LCD_CS 6
#define LCD_SDA 5
#define LCD_CLK 4
#define LCD_RSDA() (LCD_PORT->IDR&(1<<LCD_SDA))
#define SBI(port,bit) port->BSRR = (1<<bit)
#define CBI(port,bit) port->BRR  = (1<<bit)
#define memcpy_P memcpy
#define PROGMEM
#define PSTR(x) (x)
#define pgm_read_byte(x) *(x)
#define _delay_ms(x) delay_ms(x) /*Define this Function in External Source*/
#endif
« Last Edit: December 11, 2023, 12:01:04 am by DavidAlfa »
The following users thanked this post: vortex
  • Country: ma
« Reply #2 on: December 11, 2023, 12:48:29 am »
thank you very much DavidAlfa for your help i'm still learning i used avr before now convert to stm32 with better capability and price. RM0454 Reference manual with 990 page make you hisitate to read it
last thing to do change APB2ENR
 to
#define LCD_GPIO_Enable()   RCC->APBENR2 |= (1<<2)
Online DavidAlfa
« Reply #3 on: December 11, 2023, 01:53:50 am »
GPIO is enabled in RCC_IOPENR.
Bits 0-5 enable GPIO A-F ports.
(Read RM0454 page 151).
This would enable GPIOC clock:
#define LCD_GPIO_Enable()   RCC->IOPENR |= (1<<2)
But it seems you're using GPIOA, then:
#define LCD_GPIO_Enable()   RCC->IOPENR |= (1<<0)
But even better by using the cmsis headers:
#define LCD_GPIO_Enable()   RCC->IOPENR |= RCC_IOPENR_GPIOAEN
« Last Edit: December 11, 2023, 02:06:37 am by DavidAlfa »
