Author Topic: How to fix Stack Usage Warnings  (Read 3411 times)
Offline Red_MicroTopic starter
« on: October 19, 2021, 03:13:30 am »
I'm using IAR Workbench to program STM32. My application uses USB. I'm getting the following warning when compiling:
Warning[Ls016]: [stack usage analysis] the program contains at least one indirect call. Example: from "USB_Exc". A complete list of such functions is in the map file.
When I go to the map file, I can see the list of functions that perform unknown indirect calls.
Are these warnings serious? Would they cause issues if I ignore them?
Offline ataradov
    • Personal site
Re: How to fix Stack Usage Warnings
« Reply #1 on: October 19, 2021, 03:23:30 am »
It looks like a warning from a static code analyzer complaining that it can't analyze code with indirect/pointer calls. This is not a serious warning, there is nothing wrong with the code itself and you can ignore it.
If you write code that code analyzers like, your code would suck for humans to read.
Alex
The following users thanked this post: Red_Micro
