Hi;
i want to reverse the code as it complete first time.
for example
pin 1-pin 2-pin 3-pin 4 (its somplete)
now it should run as
pin 4-pin 3-pin 2-pin 1
i write this code but its not working in reverse order.please guide me in this way.
#include<htc.h>
__CONFIG(1,OSCSDIS & HSPLL);
__CONFIG(2,BORDIS & PWRTDIS &WDTDIS);
__CONFIG(3,CCP2RC1);
__CONFIG(4,LVPDIS & STVREN);
__CONFIG(5,UNPROTECT);
__CONFIG(6,WRTEN);
__CONFIG(7,TRU);
#define _XTAL_FREQ 40000000
void delay_sec(unsigned char seconds) // This function provides delay in terms of seconds
unsigned char i,j;
for(i=0;i<seconds;i++)
for(j=0;j<100;j++)
__delay_ms(10);
void led_display(char a)
switch(a)
case 0: PORTB=0x01;PORTD=0x08; break;
case 1: PORTB=0x02;PORTD=0x04; break;
case 2: PORTB=0x04;PORTD=0x02; break;
case 3: PORTB=0x08;PORTD=0x01; break;
void main()
TRISB=0x00;
TRISD=0x00;
char a,b;
while(1)
led_display(a);
a++;
delay_sec(1);
if(a==4)
a--;
am newbie with C . please correct my code
In main, you need to initialize a before you enter the loop and you don't need b, also you need a direction, and when you reach the end you need to reverse the direction and when you reach the first one you need to change the direction again.
This should do what you want, I kept it simple but you can use a += dir;
Also you can use if (!a) for comparing to 0.
also dir *= -1 will reverse direction
and other things you can try, but that main will do what you want.
void main()
TRISB=0x00;
TRISD=0x00;
// initialize led
char a = 0;
// define direction
char dir = 1;
while(1)
led_display(a);
a = a + dir; // increment or decrement depending on direction
delay_sec(1);
if(a==4)
dir = -1;
// Edit: adjust index to be 3 so that the last LED will light up again.
// change to a = 2 if you don't want the last LED to stay on for double
// the amount of time as the rest.
a--;
if(a==-1)
dir = 1;
// Edit: adjust index to 0 so the first LED will light up again.
// change to a = 1 if you don't want the first LED to stay on for double
a++;
But if you were doing PWMs and on a different chip (PSoC 4 in my case) and using interrupts instead of delays etc, this will do like a ping pong effect across 8 leds by bouncing an dark LED from one end to the other. Kind of like the Knight Rider TV show KITT but in reverse when only one dark spot moves around instead of a bright one. But because of the PWM it transitions in between LEDs so it looks continuous to your eye.
#include <project.h>
#define BRIGHTNESS_DECREASE (1024u)
uint16 curPos;
static int direction = 1;
CY_ISR(InterruptHandler)
// Clear TC Interrupt
PWM_INTERRUPT_REQ_REG = PWM_INTR_MASK_TC;
if (direction > 0)
PWM_COMP_CAP_REG = ((PWM_COMP_CAP_REG + BRIGHTNESS_DECREASE) & PWM_16BIT_MASK);
else
PWM_COMP_CAP_REG = ((PWM_COMP_CAP_REG - BRIGHTNESS_DECREASE) & PWM_16BIT_MASK);
CY_ISR(InterruptHandler_1)
PWM_1_INTERRUPT_REQ_REG = PWM_1_INTR_MASK_TC;
if (direction > 0)
PWM_1_COMP_CAP_REG = ((PWM_1_COMP_CAP_REG + BRIGHTNESS_DECREASE) & PWM_1_16BIT_MASK);
else
PWM_1_COMP_CAP_REG = ((PWM_1_COMP_CAP_REG - BRIGHTNESS_DECREASE) & PWM_1_16BIT_MASK);
CY_ISR(InterruptHandler_2)
PWM_2_INTERRUPT_REQ_REG = PWM_2_INTR_MASK_TC;
if (direction > 0)
PWM_2_COMP_CAP_REG = ((PWM_2_COMP_CAP_REG + BRIGHTNESS_DECREASE) & PWM_2_16BIT_MASK);
else
PWM_2_COMP_CAP_REG = ((PWM_2_COMP_CAP_REG - BRIGHTNESS_DECREASE) & PWM_2_16BIT_MASK);
CY_ISR(InterruptHandler_3)
PWM_3_INTERRUPT_REQ_REG = PWM_3_INTR_MASK_TC;
if (direction > 0)
PWM_3_COMP_CAP_REG = ((PWM_3_COMP_CAP_REG + BRIGHTNESS_DECREASE) & PWM_3_16BIT_MASK);
else
PWM_3_COMP_CAP_REG = ((PWM_3_COMP_CAP_REG - BRIGHTNESS_DECREASE) & PWM_3_16BIT_MASK);
CY_ISR(InterruptHandler_4)
uint16 input1, input2;
PWM_4_ReadStatusRegister();
input1 = PWM_4_ReadCompare1();
input2 = PWM_4_ReadCompare2();
if (direction > 0)
PWM_4_WriteCompare1(input1 + BRIGHTNESS_DECREASE);
else
PWM_4_WriteCompare1(input1 - BRIGHTNESS_DECREASE);
if (direction > 0)
PWM_4_WriteCompare2(input2 + BRIGHTNESS_DECREASE);
else
PWM_4_WriteCompare2(input2 - BRIGHTNESS_DECREASE);
CY_ISR(InterruptHandler_5)
PWM_5_ReadStatusRegister();
input1 = PWM_5_ReadCompare1();
input2 = PWM_5_ReadCompare2();
if (direction > 0)
PWM_5_WriteCompare1(input1 + BRIGHTNESS_DECREASE);
else
PWM_5_WriteCompare1(input1 - BRIGHTNESS_DECREASE);
if (direction > 0)
if (((input2 + BRIGHTNESS_DECREASE)&0xFFFFu) < input2)
direction = -1;
else
PWM_5_WriteCompare2(input2 + BRIGHTNESS_DECREASE);
else
if(((input2-BRIGHTNESS_DECREASE)&0xFFFFu) > input2)
direction = 1;
else
PWM_5_WriteCompare2(input2 - BRIGHTNESS_DECREASE);
int main()
CyDelay(50u);
// Enable the global interrupt
CyGlobalIntEnable;
// Enable the Interrupt component connected to interrupt
TC_ISR_StartEx(InterruptHandler);
TC_ISR_1_StartEx(InterruptHandler_1);
TC_ISR_2_StartEx(InterruptHandler_2);
TC_ISR_3_StartEx(InterruptHandler_3);
TC_ISR_4_StartEx(InterruptHandler_4);
TC_ISR_5_StartEx(InterruptHandler_5);
// Start the components
PWM_Start();
PWM_1_Start();
PWM_2_Start();
PWM_3_Start();
PWM_4_Start();
PWM_5_Start();
// Set periods
PWM_WritePeriod(65535u);
PWM_1_WritePeriod(65535u);
PWM_2_WritePeriod(65535u);
PWM_3_WritePeriod(65535u);
PWM_4_WritePeriod(65535u);
PWM_5_WritePeriod(65535u);
// Init dual PWMs
PWM_WriteCompare(BRIGHTNESS_DECREASE-1u);
PWM_1_WriteCompare(8192u+(BRIGHTNESS_DECREASE-1u));
PWM_2_WriteCompare(2*8192u+(BRIGHTNESS_DECREASE-1u));
PWM_3_WriteCompare(3*8192u+(BRIGHTNESS_DECREASE-1u));
PWM_4_WriteCompare1(4*8192u+(BRIGHTNESS_DECREASE-1u));
PWM_4_WriteCompare2(5*8192u+(BRIGHTNESS_DECREASE-1u));
PWM_5_WriteCompare1(6*8192u+(BRIGHTNESS_DECREASE-1u));
PWM_5_WriteCompare2(7*8192u+(BRIGHTNESS_DECREASE-1u));
for(;;)
A little revision.
void main()
TRISB=0x00;
TRISD=0x00;
// initialize led (we pre-increment/decrement so -1 on a positive direction will end up as 0)
char a = -1;
// define direction, 1 forward, -1 backwards.
char dir = 1;
while(1)
a += dir;
led_display(a);
delay_sec(1);
// reverse direction if we reach either the last LED (3) or the 1st one (0)
if ((a==0)||(a==3))
dir *= -1;
Thank you so much . i ll try this.
actually these are early days for me to work with C.your help will make me experienced..i ll reply again as i test this code and run it..
Thank you
It's not going to happen with your display routine: it presumes a certain data pattern.
Instead, turn off all digits and then just light up the digit you wish to light up.
Once that's done, alter the pattern of data to be displayed.
Something like this:
for (pattern=0x01; pattern < 0x10; pattern = patter << 1) {led_display(pattern); delay_ms(LED_DLY);}
for (pattern=0x08; pattern; pattern = patter >> 1) {led_display(pattern); delay_ms(LED_DLY);}
now i want to turn on led in a sequence i.e
1 3 2 4
now what should i do???
change the case statement entries, either the index or the code for that index.
actually i want to change the logic only..
i understand your comment..
i tried this
void main()
TRISB=0x00;
TRISD=0x00;
// initialize led
char a = 0;
// define direction
char dir = 1;
while(1)
led_display(a);
delay_sec(1);
if(a==2)
dir = -1; // here a become a=2-1=1
a+=2; // here a become 1+2=3
what about my logic???
Not going to happen.
You will find that programming is a lot easier if you start simple. In this case, start by turning a pin on / off. Once you do that, we will go from there.
I agree
it's easier if you change your case statement, each one determines a state.
case 0: somecode_to_light_led1; break;
case 1: somecode_to_light_led2; break;
case 2: somecode_to_light_led3; break;
case 3: somecode_to_light_led4; break;
You can either change the case number:
case 2: somecode_to_light_led2; break;
case 1: somecode_to_light_led3; break;
Or the code for the case:
