EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
Implementing Peter Fleury's UART library
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Implementing Peter Fleury's UART library (Read 2187 times)
Simon
Global Moderator
Country:
Did that just blow up? No? might work after all !!
on:
May 27, 2018, 08:44:56 pm »
So my knowledge of C is not the most robust but Peters library looks well documented. However I see that before I even give it a go there is a "makefile.uart".
OK before i try and
what do I do with this file? Everything else looks fine, a .c file a .h file and a sample program.
Logged
ataradov
Super Contributor
Country:
Re: Implementing Peter Fleury's UART library
Reply #1 on:
May 27, 2018, 08:52:37 pm »
Typically you include that into your main Makefile. Or at least look at what "unusual" compiler options are passed in that makefile.
In reality it is probably just a part of a big compartmentalized build system, and you can just use the files in your project without even looking at this file.
Logged
Alex
Simon
Global Moderator
Country:
Reply #2 on:
May 27, 2018, 08:56:22 pm »
See attached. I use Atmel Studio so I'm not sure what to do with this if anything.
Logged
ataradov
Super Contributor
Country:
Reply #3 on:
May 27, 2018, 08:58:15 pm »
Don't do anything with is, just add files to your project. If the code does not compile and complains about some defines missing (like F_CPU), then just define them yourself in the AS project settings.
Logged
Alex
Simon
Global Moderator
Country:
Reply #4 on:
May 27, 2018, 09:00:31 pm »
OK thanks
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
