Author Topic: Is there a way to program microcontroller with python code?  (Read 4927 times)
Offline samdareTopic starter
  • Country: in
I am sort of good at python compared to C++,assembly and C and actually I love python compared to all other languages (no specific reason).So I just want to club python and embedded electronics is there a way that python hooks with microcontroller or vice versa :-D
Sent from my Lenovo K8 Plus using Tapatalk
The following users thanked this post: e100
Offline lgbeno
Online Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Is there a way to program microcontroller with python code?
« Reply #2 on: March 30, 2018, 09:30:46 pm »
Unlikely. There are some projects doing javascript though.
In general, running an interpreted language on a microcontroller is highly inefficient. If interpreted languages are used, they are often limited to user programmable equations in larger programs. Eg: A PLC formula fields.
Just learn to type { and ; instead of [tab] and you'll be good to go!   :P
  • Country: in
« Reply #3 on: March 30, 2018, 09:31:17 pm »
Yes https://learn.adafruit.com/welcome-to-circuitpython/what-is-circuitpython
Sent from my iPhone using Tapatalk Pro
Just had a glance, looks cool ,thanks
  • Country: in
« Reply #4 on: March 30, 2018, 09:32:47 pm »
Just learn to type { and ; instead of [tab] and you'll be good to go!   [emoji14]
[emoji23][emoji23][emoji23] quality humor.
  • Country: in
« Reply #5 on: March 30, 2018, 09:35:35 pm »
JavaScript!!,repository names?
Online Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #6 on: March 30, 2018, 10:06:00 pm »
  • Country: in
« Reply #7 on: March 30, 2018, 10:10:12 pm »
https://www.espruino.com/ is one of them.
Thanks
Offline abraxa
  • Sigrok associate
« Reply #8 on: March 31, 2018, 08:01:59 am »
There's also http://micropython.org/ - it's the foundation for the https://openmv.io/, for example.
  • Country: in
« Reply #9 on: March 31, 2018, 08:05:07 am »
The openmv site outdated ,404 error
Offline brtmr
« Reply #10 on: March 31, 2018, 09:21:59 pm »
This thing https://en.wikipedia.org/wiki/Micro_Bit was handed to me at a Python conference last year. Developed for UK schoolkids to learn programming. Maybe it could also be for programmers who want to get started on microcontrollers?
Edit: This is the online IDE you can use:
http://python.microbit.org/v/1
Website IDE turns your Python code into a downloadable binary blob, you plug in your micro into your PC, it shows up as a hard drive, you copy the blob to the drive, done.
« Last Edit: March 31, 2018, 09:25:14 pm by brtmr »
Offline igendel
  • Country: il
    • It's Every Bit For Itself (Programming & MCU blog)
« Reply #11 on: March 31, 2018, 09:55:32 pm »
As mentioned, there's CircuitPython and MicroPython, each with its "native" boards. The difference, to the best of my knowledge, is that MicroPython was optimized specifically for MCUs in some ways, while CircuitPython tries to stay true(r) to the original Python syntax.
Both are very limited. Obviously you can't just import any Python library, and what you do have will be slow and heavy on the microcontrollers' resources. I've done a couple of little demo projects on the BBC Micro:bit and a Pyboard clone from China. It's fun, arguably excellent for getting children interested in embedded/programming, but for more serious work you'll hit the limitations of these languages very fast.
Maker projects, tutorials etc. on my Youtube channel: https://www.youtube.com/user/idogendel/
Offline e100
« Reply #12 on: April 04, 2018, 09:53:32 am »
CircuitPython = MicroPython + Adafruit's device drivers for talking to Adafruit developed hardware.
Offline e100
« Reply #13 on: April 04, 2018, 10:07:01 am »
Do a Google search for "micropython memory fragmentation" before going down this road.
If high reliability is important, then Python may not be the best solution.
Offline igendel
  • Country: il
« Reply #14 on: April 04, 2018, 10:31:22 am »
Ah, found it:
https://theamphour.com/383-an-interview-with-scott-shawcroft/
(from 28:00)
