I'd look at your customers and see what fits their needs. C/C++/C# seem much easier to me to deploy because you can create a single installer blob which doesn't depend on a third party runtime (the Java runtime can be upgraded and cause all kinds of breakage).
For backend work I'd say Java is out.
QuoteFor backend work I'd say Java is out.Although not my expertise this is what I hear from our AWS developers as well. On the cloud servers you don't want code that needs to be interpreted by another run time library, that cost space and time both which are cloud expenses. They now talk about lambda functions written in for instance Python, much faster and much cheaper, but definitely not my expertise so I shut up
Electron / Qt / WxWindows / Java+SWT / native apps per platform is the way to go. Something that insulates you from any specific platform volatility.
Python is quick to write but very slow to execute. It really is a turd in production as well. I've managed it and we scrapped it in the end. Go is eating it's lunch on the server-side at the moment as it's half way between python and C.
It's not quite CSP as per Hoare's paper on the matter, but yes it is being used heavily. We're using it for a few things from constraint solvers to stuff as dumb as evaluating rules to shift http content. A lot of our constraints involve talking to other 3rd parties so most of the IO is blocking so at allows lowest latency simply through running everything in thousands of goroutines with channel based synchronisation. Also makes failures easy to rationalise.
It's fun as well which is a missing thing these days in most platforms!
Really Erlang is probably a better choice on paper but the learning curve and library support is pretty bad.
Incidentally and not a lot of people know this, most of the NHS's spine2 backbone which is one of the largest and most well hidden bits of "enterprise" kit out there runs on Ubuntu with Erlang and Riak and a big chunk of gov.uk runs on Go as well.
Java is huge in corporates. It's the new COBOL.
I think that's an excellent way to put it!
Now the question is, am I trying to keep up with corperates/mindset/integration or am I doing something newer/better? For me, I see Java and despite it's "glorious potential" I get ram heavy dumbness. Why would I choose Cobol [Java]?
So to the OP, yea, IDK, but if you aren't using it now and don't need to - I don't know why you'd switch. Again, I'd probably fire someone who came to me in my line of work and suggested Java as it would be so out of place and regressive.
There is also perhaps a lesson here for you as a boss - never dismiss anything out of hand. There is usually(always?) some clever thing hiding in any stupid sounding idea, but you have to open your mind to be able to see it. Defer it if you need to, but never dismiss it without giving it some thought and the person a chance to explain.
As for client facing applications though, I'd probably ship Electron now: https://electron.atom.io
The thing with Java is (a) it's actually pretty good in most locations (b) if you can use it in most locations it makes people's skills fungible which is good (c) it's perfectly fine for *everything* other than hard real time systems as tgzzz says but even then some of the embedded JVM and cross compiled Java products are actually pretty good believe it or not (d) there are a lot of mature frameworks out there that make it very easy and reduce the time to market.
Getting a product written in C# off the ground is a monumentally stupid decision at the moment as the platform is going through a transition phase between "corporate Microsoft" and "happy shiny open source Microsoft" but the ship has sailed and the house of cards is falling on the last half.
For client side I think pretty much any sane person by now has accepted that apps need to be native, which means C# on Windows, Swift on Apple, Java on Android, etc. This is generally simpler than trying to generalize something that runs everywhere but provides a really ghetto UX - penny wise, pound foolish to the extreme.
I think that a near future , the programmers will be fired and replaced by AI software for doing the 90% of the code , after the humans will link the parts of the software.
Even humans haven’t worked out how to write software yet. In the scale of things, comparing to any other engineering discipline, we’re still at the stage of massive Victorian style train wrecks. AI also doesn’t really exist yet. I’d be surprised if we have anything as good as a cat in the next 50 years or so (Kurzweil is full of shit) and cats lick their own butt hole. Even IBM’s research in this area turned out to be a mechanical Turk.
I agree regarding legislation and AI, this is going to be a rocky road. If you make something that inadvertently turns out to be dangerous, you are at risk of being deemed negligent. I’d suggest if you don’t know how your machine is making its decisions, and it is not sufficiently limited by enough safeguards, then that is negligence, and you are liable.
