Author Topic: just found this programmer  (Read 5120 times)
Offline siliconmixTopic starter
  • Country: wales
Offline jimmc
Re: just found this programmer
« Reply #1 on: February 01, 2012, 01:23:33 pm »
I'm getting a 404 on that link.
Jim
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
« Reply #2 on: February 01, 2012, 01:28:02 pm »
just drop the '.' after htm
alm
  • Guest
« Reply #3 on: February 01, 2012, 01:45:12 pm »
This is not a programmer, just a convoluted solution replacing a MAX232 by something not conforming to the RS-232 spec: funny stuff if flow control kicks in, no negative voltages, may not be happy if the output is shorted or connected to +/- 25 V.
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
« Reply #4 on: February 03, 2012, 06:56:05 am »
I used a similar setup for dumping the DVD-rom drive key from my Lite-on Xbox 360 drive. It work's ok depending on your Serial port hardware and what you are trying to do, but in a pinch it works ok :)
  • Country: wales
« Reply #5 on: February 03, 2012, 08:20:22 am »
thanks  .i should imagine it's quite stable using the fets.
Offline deephaven
    • Deephaven Ltd
« Reply #6 on: February 03, 2012, 09:02:42 am »
You can make your own Pickit 2 see here: http://www.obddiag.net/picprog.html
It uses a programmed PIC itself, if you need a hand in getting that I can program it for you.
  • Country: wales
« Reply #7 on: February 03, 2012, 09:04:01 am »
cheers.might take you up on that.
Offline westfw
« Reply #8 on: February 04, 2012, 01:29:35 am »
The first time I saw this (or similar mosfet-based circuit), I got a distinct uncomfortable feeling about mosfet gates connected mostly directly to external wires of indeterminate length.  When I asked around, I did get some comments to the effect that it did tend to burn out, so I reverted to the original Serial Arduino circuit (this was for a single-sided serial Arduino.)
