Fluke 19X/B/C/II Firmware to Binary converter
FlukeFW2Bin.exe takes the firmware file (Tetra.ldf, or data.bin) from within Fluke's FlashTool
(F190_II_V11.44.exe, FlashTool_19xC_2xC_V804.exe, FlashTool_F190C_V615.exe, etc.)
and converts it into 2 binary files for analysis purposes.
Use:
just open a console where the exe is located and write:
C:>\FlukeFW2Bin\FlukeFW2Bin.exe data.bin
and it will create two binary files.
The firmware on these Fluke Scopes uses the Nucleus PLUS - Version CL7111A RTOS what means
the uP is some form of ARM little-endian CL7111A probably similar to CIRRUS LOGIC CL-PS7111
The produced files binary must be loaded at 0x40000000 and 0x44000000
Entry point 0x40000080
Edit 01:
Tektronix THS3014/3024 apparently is a Fluke 190-104/204 II.
Edit 02 6/18/2025:
FlukeFW2Bin.zip SHA-2 (256) = 0AFD4B0747214B114CA4C992D3E3CECD2EEB21419F6EB619610976F82A255F9A
The file currently offered by EEVblog is not corrupted and I can perfectly extract it with 7z
