EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
L1 cache causing error in bootloader
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: L1 cache causing error in bootloader (Read 4414 times)
jtronix
Regular Contributor
on:
April 13, 2016, 11:25:14 am »
I'm working with renesas RZ A1H cortext A9 processor and i have one problem with Boot loader. In boot loader if L1 cache is initialize then it wont jump to the user application and it stuck after jump function. also I'm initializing L1 cache again in my user application.
Everything works fine if L1 cache is not initialize in bootloader.
Logged
tszaboo
Super Contributor
Country:
Current job: ATEX product design
Re: L1 cache causing error in bootloader
Reply #1 on:
April 13, 2016, 11:29:06 am »
If this is just a "public announcement", then I would like to add, that the ART accelerator, which is a cache to the Flash on the STM32 MCUs, also cause issues when bootloading.
I would just turn off any caching on any architecture when bootloading.
Logged
Measure power rails with 2GHz bandwidt:
https://eleshop.eu/prp1-power-rail-probe.html
jtronix
Regular Contributor
Reply #2 on:
April 13, 2016, 11:33:28 am »
How to overcome this issue of cache?? In bootloader i need cache to perform operation faster but it wont booting my application.
Is there any steps that needed before jumping to the user application???
Logged
tszaboo
Super Contributor
Country:
Reply #3 on:
April 13, 2016, 11:47:16 am »
On that MCU the issue was:
10 The MCU was containing code.
20 We overwrote the Flash.
30 We were expecting that the new code will be excecuted, but the old was, since it was in the cache
The solution was to 25 flush the cache. Or to turn it off if possible.
Last Edit: April 13, 2016, 11:49:14 am by NANDBlog
Logged
andersm
Super Contributor
Country:
Reply #4 on:
April 13, 2016, 01:22:03 pm »
On some architectures, the caches contains random garbage on powerup and needs to be cleared before being enabled.
Logged
TNKernel-PIC32, an open-source real-time kernel for the PIC32
jtronix
Regular Contributor
Reply #5 on:
April 14, 2016, 04:09:21 am »
do you have cache flush assembly code for cortex A9 processor or programming guide ?
Logged
andersm
Super Contributor
Country:
Reply #6 on:
April 14, 2016, 05:11:46 pm »
You can probably find code easily on the net (eg. any open-source OS that supports the Cortex-A9). The cache maintenance operations are performed via CP15, and are documented in the ARMv7-A architecture reference manual, and the Cortex-A9 technical reference manual for the core-specific bits.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
