Author Topic: LCD interfacing  (Read 3661 times)
Offline R_G_B_Topic starter
LCD interfacing
« on: October 18, 2013, 06:39:37 pm »
Hi I am am starting a project... interfacing a FPGA to a LCD. What I would like to know is where can I get a LCD display.
My preference is:
3.5 - 4.2 inch monochrome display 3.3V max.
320x240 pixel resolution
Also when they refer to the FPGA as being a display driver. My understanding from this is that the FPGA drives the displays onboard control chip. Have I understood this correctly correct?
Thanks in advance.
R_G_B
R_G_B
Offline AndyC_772
Re: LCD interfacing
« Reply #1 on: October 18, 2013, 07:00:31 pm »
Mouser has a pretty good selection of LCD displays, you should be able to find one easily enough there.
Usually an off-the-shelf mono display will have a driver IC included, which contains the frame buffer and generates the waveforms which physically drive the panel. The host device - usually a microcontroller rather than an FPGA - talks to the LCD controller over SPI, I2C or a parallel port. Only changes to the displayed image need to be sent over the interface.
If you were using a TFT colour panel - something which might be expected to display video - then they're typically driven much more directly, ie. you have to clock data in continuously, a pixel at a time. This is the type of display which is more often driven with an FPGA.
Re: LCD interfacing
« Reply #2 on: October 18, 2013, 08:44:08 pm »
"If you were using a TFT colour panel - something which might be expected to display video - then they're typically driven much more directly, ie. you have to clock data in continuously, a pixel at a time. This is the type of display which is more often driven with an FPGA."
Yes This is what I want to do. I have managed to find a FSTN positive display which should do the trick. Dont seem to be able to find the faster TFT LCD graphics display
The FPGA will be updating the display in realtime e.g continuosly at a pixel at a time as well as dumping realtime data into memory.
So concurrent processing is important.
I got a bit confused because all I could find at the time was LCD graphic displays that had control boards on them.
« Last Edit: October 18, 2013, 09:04:28 pm by R_G_B_ »
R_G_B
Offline denizcan
Re: LCD interfacing
« Reply #3 on: October 18, 2013, 09:24:21 pm »
If they didn't have, you also would have to generate analog signals that drives the LCD..
Offline GeoffS
Re: LCD interfacing
« Reply #4 on: October 18, 2013, 10:06:48 pm »
Take a look at http://www.wayengineer.com/index.php?main_page=index&cPath=6&zenid=cae4ad846d2c5148de45ee1554eb4504
They have an enormous range and their prices are pretty cheap.
Re: LCD interfacing
« Reply #5 on: October 18, 2013, 10:11:51 pm »
Yes thats right.
The LCD has a digital interface. the only thing lacking or NOT lacking is the control board or driver to drive the pixels on the screen. The FPGA was decided because of the the application in this example speed of display update while doing other things at the same time.
Thanks
« Last Edit: October 18, 2013, 10:17:40 pm by GeoffS »
R_G_B
Re: LCD interfacing
« Reply #6 on: October 18, 2013, 10:14:32 pm »
Thanks for this Geoffs:
« Last Edit: October 18, 2013, 10:18:21 pm by GeoffS »
R_G_B
