Author Topic: JLink script for bcm2837  (Read 4170 times)
Offline dobsonr741Topic starter
« on: March 29, 2024, 03:16:39 pm »
I wonder if anyone mastered connecting to bcm2837 with JLink and the Segger provided tools? OpenOCD can and does connecting fine using Link hardware. However, I want to use RTT, and that needs the native Sagger tooling. So I tried a few variations of jscript, attempting to configure CTI and debug base with no success.
JLINK_CORESIGHT_CoreBaseAddr    = 0x80000000;
JLINK_ExecCommand("CORESIGHT_SetCSCTICoreBaseAddr=0x80018000");
It all ends up in:
No AP map specified by user. Setting auto-detected AP map.
DebugRegs + CTI manually specified. ROM table scan skipped.
Failed to identify core.
****** Error: Debug registers of core not found. Debugging not possible
Could not determine core debug registers + core CTI. Debugging not possible
The addresses are well know by OpenOCD, what is a working translation of them into Segger dialect?
set _DBGBASE {0x80010000 0x80012000 0x80014000 0x80016000}
set _CTIBASE {0x80018000 0x80019000 0x8001a000 0x8001b000}
Offline GromBeestje
Re: JLink script for bcm2837
« Reply #1 on: March 31, 2024, 03:55:51 pm »
I don't know how to make it work with Segger's software, if it is RTT you are after, it is supported by recent versions of OpenOCD.
Offline __george__
  • Country: no
« Reply #2 on: April 01, 2024, 09:09:36 pm »
It's a long time since I wrote a JLink script but I do remember that I had to oveload an initialization function for it to work. Searching a bit on github seems to confirm what I remember:
https://github.com/kamejoko80/my_osek/blob/6dcf8a748e1d3b9b43ddcc94c077d3cd970b0d7e/NEO_M4_OSEK/tool/IMX6SX_WITH_JLINK_V1.0/IMX6SX_HOW_TO_DEBUG_CORE_M4.txt#L71
But from your error message it seems that if you manually add the API as the github code shows you should go at least one step further.
