Author Topic: looking for a drop in eeprom replacement for AM27C040  (Read 4754 times)
Offline RogueBotixTopic starter
« on: December 09, 2017, 05:46:48 pm »
I am having a hard time finding a replacement to replace an AM27C040 with an eeprom. Have some old boards that I need to update the firmware, I don't have an erasing lamp, so I figured if I just find a eeprom replacement that would be easier. I am not very knowledgeable in this field. Thanks for your help.
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
Re: looking for a drop in eeprom replacement for AM27C040
« Reply #1 on: December 09, 2017, 05:56:57 pm »
You could try W27E040-12.
Also, EPROM eraser lamps can be had for a couple of bucks from ebay or local small ads.
He’s like a trained ape. Without the training.
« Reply #2 on: December 09, 2017, 07:07:47 pm »
I still would like to find one electronically erased since I might have to do it multiple times.
Offline frozenfrogz
« Reply #3 on: December 09, 2017, 07:32:11 pm »
Please take a second look at the part I proposed. It is an EEPROM and not a UV-EPROM. It should be pin compatible and up to specs if I am not mistaken.
« Reply #4 on: December 09, 2017, 08:06:06 pm »
Oh my bad, many thanks!
Offline frozenfrogz
« Reply #5 on: December 09, 2017, 08:11:40 pm »
You are welcome. Good luck with your project :)
Online westfw
« Reply #6 on: December 09, 2017, 09:38:53 pm »
A generic replacement for 27c040, in flash technology, would be 29f040
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #7 on: December 18, 2017, 02:55:51 pm »
The problem would be pin compatibility - are 29F040 drop-in replacement for 27C040?
My personal favorite is actually one of those SD-based flash cartridges used in certain game consoles. However still, pin compatibility.
