Author Topic: Looking for PAL/GAL Dev Tools  (Read 6143 times)
Offline marcopoloTopic starter
« on: August 27, 2018, 02:29:06 pm »
I'm looking for a compilation/simulation software for the PAL & GAL I have at home (a lot of 16R6, 20R4,20R8,22V10,26CV12 and 20X10)
and if I can use the same software for ALTERA MAX5000/7000 and AMD MACH1/MACH2, it would be perfect  :)
Operating system: From Windows 95 to 7
I'm open to ABEL,CUPL,Verilog, ... but not VHDL
I checked MachXL 6.0 & 6.2 documentation : PAL20X10 not supported
I tried the PLD module from Protel99 under XP, not very stable and strange behavior
Old Orcad had a PLD module but I think it supported only VHDL.
DOS PalAsm: No thanks  :palm:
Thanks for your help.
Marc
Offline PCB.Wiz
Re: Looking for PAL/GAL Dev Tools
« Reply #1 on: August 28, 2018, 12:51:15 am »
You can still download WinCUPL, the Atmel-focused version.
http://www.microchip.com/design-centers/programmable-logic/spld-cpld/tools/software/wincupl
- but that will not support the stranger parts - you are best to bin those.
ATF22V10 is fine, and ATF1502ASL / ATF1502BE will swallow those other SPLDs (in a modern Icc/Vcc/Package).
If you want more portable, there is also MyHDL ?
Verilog is probably the best looking forward, and there are some 'open FPGA efforts' around lattice FPGAs ?  eg https://github.com/cliffordwolf
« Reply #2 on: August 28, 2018, 09:28:58 am »
You think I'd better throw them away but I like to use old SPLD/CPLD/FPGA and I have more than 1000 PAL at home, so no way  :)
Offline PCB.Wiz
« Reply #3 on: August 28, 2018, 10:09:03 am »
Then good luck on your quest....
An alternative approach, if you have lots of spare time, is to make your own back-end to the tools.
CUPL compiles to a Berkley PLA file IIRC, and the Atmel ATF15xx fitters use that, to create the fuse-maps.
You made the 20X10 bold, so I guess that one is a focus item - is that OTP, or EE based  ? I presume you have a working programmer for that device ?
It may be possible to merge/massage a 22V10 fuse info file, with whatever makes that 20X10 different ?
or, there are better 22V10, that used to come from ICT, and google finds
http://www.vcfed.org/forum/archive/index.php/t-40469.html
and the last post there in 2017, has a link that looks still alive to ICT PLACE
« Reply #4 on: August 28, 2018, 07:51:46 pm »
Yes PAL20X10 is a focus item. It's an OTP Registered PAL with a XOR before the Flip-Flop.
I have 2 programmers for them (Elnec BeeProg+ and Data I/O Unisite)
I checked today Vantis Design Direct: 20X10 not supported  :(
Offline TK
« Reply #5 on: August 28, 2018, 09:41:51 pm »
It looks like PALASM supports PAL20X10... you can run it under DOSBOX.  I recently used it to enable IBASIC option an old HP Vector Network Analyzer (HP 8714B).
https://www.eevblog.com/forum/testgear/how-to-activate-ibasic-on-vintage-hp-871xb-network-analyzers/msg1251274/#msg1251274
Offline romhunter
  • Country: vn
« Reply #6 on: September 03, 2018, 03:05:00 pm »
May I ask what did you use to program those PAL/GAL? The programmer and the program you use to load it?
Offline TK
« Reply #7 on: September 03, 2018, 05:11:15 pm »
I used the MiniPro TL866 Universal Programmer
