CH347 It can operate in several modes, including JTAG-SWD. Low startup speed must be enabled in the communication settings, otherwise the ARM chips will malfunction. At high speed, the wires should be no longer than 5 cm; it's best to solder them directly to the board nearby.
Pros: it doesn't heat up like the ST-Link V3 MINIE, it can be used as a programmer (very quickly), the active components measure 20 x 12 mm, and it's sold on AliExpress as an original (no counterfeits).
