Author Topic: LUA interpreter : how to autostart a lua program  (Read 3410 times)
Offline free_electronTopic starter
    • SiliconValleyGarage
« on: July 06, 2016, 10:18:18 pm »
anyone using eLUA on Cortex ?
i want to know how i can run a lua program automatically on startup. google is broken ...
basically : is there an autoexec.bat ?
Offline bson
Offline joseph nicholas
  • Country: mx
Re: LUA interpreter : how to autostart a lua program
« Reply #2 on: July 06, 2016, 11:45:41 pm »
The default for that is init.lua.  It runs automatically on start up.
« Reply #3 on: July 07, 2016, 05:16:30 pm »
so if i add an init.lua to the rom filesystem that one will run ?
i want to make a small self starting lua script that checks for the presence of a flash memory on spi or i2c. if the memory is found and it contains a specific signature it will create a new file in the write once filesystem and copy the data from the eeprom over. this then becomes a new lua program that is called and launched.
Think of it as a small LUA bootloader.
lua starts and then launches my loader. this loader checks for the existence of an eeprom. if it exists : read signature. then : check eif app.lua exists in internal worm. if it does : compare signatures. if they match  :run app.lua. if they dont match : cope eeprom contents in new app.lua and then launch app.lua
the idea is to have the control program for a sensor reside in the sensor. if i plug it into the system (lua based) this will detect the sensor and automatically install the driver for it.
Offline chipah
« Reply #4 on: July 12, 2016, 12:36:04 am »
I work with the open source Apache Mynewt OS that has a lua interpreter:
https://mynewt.apache.org/latest/os/modules/elua/elua/
There is a sample app on github (app called "latest") that currently initializes lua via shell (so you can manually run the lua script at the prompt).
https://github.com/apache/incubator-mynewt-core/blob/master/apps/luatest/src/main.c
The shell command calls the lua_main(argc, argv) as shown in
https://github.com/apache/incubator-mynewt-core/blob/master/libs/elua/elua_base/src/lmynewt.c
You could write an app that calls lua_main() to start automatically on some trigger or periodically.
