Author Topic: M27C1001 replacement  (Read 2432 times)
Offline IconicPCBTopic starter
« on: September 04, 2019, 03:35:22 am »
Looking for the UV erasable version of M27c1001 memory chip in PLCC package.
So far all searches suggest no longer available anywhere in the wild.
If anybody knows of or can recommend  pin for pin replacement part in either UV or electrically erasable variant..please advise.
Online oPossum
Re: M27C1001 replacement
« Reply #1 on: September 04, 2019, 03:46:56 am »
27C010 is pin compatible.
Online oPossum
« Reply #2 on: September 04, 2019, 03:48:22 am »
« Last Edit: September 04, 2019, 03:50:26 am by oPossum »
« Reply #3 on: September 04, 2019, 03:49:25 am »
oPossum there is a warm dry spot in my attic of gratitude for You.
Offline james_s
« Reply #4 on: September 04, 2019, 03:51:34 am »
UV erasable is probably tricky but electrically erasable should be trivial to find, the M27C1001 uses a standard JDEC pinout so just find any 5V capable PLCC32 EEPROM that is at least 128k x 8.
