Normally you cannot see what is what as the transistors are at the "bottom" and on top of that is the power and signal wiring, my guess is that top left is ram left bottom is flash and the "rusty" part is the peripherals and the CPU, the lower right corner can be power regulators and clock Machinery ( i.e
the most basic stuff as that would not contain so much transistors and then there is not much wiring on top
