Author Topic: Mechanics of MCU startup  (Read 8262 times)
Offline Sherlock HolmesTopic starter
Re: Mechanics of MCU startup
« Reply #75 on: February 15, 2023, 02:58:39 pm »
Well after much discussion with others it has emerged that a useful improvement will be to have a thing that looks a bit like a procedure or function but is not, it could be simply called an "intrinsic" a new kind of entity. Then implement things so that it is only inside an "intrinsic" that one can embed assembler, it will not be possible to embed assembler freely in any old code.
Furthermore an intrinsic will specify a target in some way, perhaps as simply as "target(x64)" and then only the intrinsics that target the same target (as the compiler when it builds) will be visible and accessible to the rest of the code and if there are multiple intrinsics with the same name but differing targets, the can be resolved on that basis.
An intrinsic will appear like a procedure or function when referenced, but will not be, it will represent a literal embedding of the associated machine instructions with support for passing arguments and returning values in a similar way to many of today's common C intrinsics.
Yes, this pattern is already in use in some high-performance computational software in Linux.  I've used it myself.  In GNU C/C++, it look roughly like
    __attribute__((always_inline, target("machine-dependent-options")))
    static inline return_type name(args...) {
        return_type return_value; // and any other local variables
        asm volatile( "extended assembly"
                    : output-operands // return_value
                    : input-operands
                    : clobbers );
        return return_value;
See common function attributes and extended asm for the details.  This is supported by both GCC and Clang C and C++ frontends, although some of the attribute names and definitions vary a bit; better use preprocessor macros.
The key here is that it is extended assembly, not just copy-pasted to an assembler and the result included in the object code.  Instead of specifying exact register names, you define operands, with their constraints specifying which registers the compiler may choose for each operand.  Each operand is automatically numbered in order they're defined from %0 onwards, but can also be named.  For example, on 32-bit x86, you might use
__attribute__((always_inline, const))
static inline int64_t mul32(const int32_t lhs, const int32_t rhs) {
    int64_t result;
    asm volatile ( "imul\t%2"
                 : "=A" (result)
                 : "a" (lhs), "r" (rhs)
    return result;
instead of ((int64_t)((int32_t)(lhs))*(int64_t)((int32_t)(rhs))), to ensure you get a 64-bit product from two 32-bit multiplicands.  The x86 imul machine instruction requires one multiplicand to be in the eax register (a constraint), but the other can be in any register (r constraint); and the result is put in edx:eax register pair (A constraint).
(We could also have used the named version, "imul %[rh]" : "=A" (result) : "a" (lhs), [rh] "r" (rhs) ; but the numbering is more common.  I find the named version easier to maintain.)
(In case you wonder, the GCC convention is to add newline and tab, \n\t, after each instruction, but not after the last instruction.  Due to how GCC does this, this makes the code look "normal" if someone compiles the file to assembly using -S, like e.g. Compiler Explorer does.)
When inlining, the compiler can choose the registers used to reduce unnecessary register moves.  This is very important, because it means that instead of simply plopping down a copy of the inlined body, the compiler can optimize both the inlined body register choices, and the surrounding code, at the back-end/machine code level.  (In other words, this is not usually translatable to intermediate representation... but it can yield pretty tight inlined code.)
Obviously, looking at this example above, the syntax GCC/Clang use for this is pretty bad.  Nobody remembers the machine constraints; a list of allowed registers (and memory reference types) would be much better, for example.  Also the named operand format in the assembly, %[name], is pretty cumbersome.
One option to consider is to let the entire function/intrinsic body be written in an assembly-like language, which is compiled by the same compiler, so that it can determine the possible registers to be used automatically, for example.  This would be a very nice mechanism to embed other-language function-like objects, like OpenCL/CUDA/GPGL computing kernels, pixel shaders, and so on, in a much easier to maintain way; but it would require either a multi-language compiler, or co-operating compilers.  But this is just one option to consider, and I'm just describing what I've thought of before myself having used the above pattern in real-world code (and how annoying it is to maintain – faster to rewrite, really, than it is to debug); I'm pretty sure there are even better ways of doing this.
Thanks, this is exactly the kind of thing I'm exploring, much appreciated.
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” ~ Arthur Conan Doyle, The Case-Book of Sherlock Holmes
« Reply #76 on: February 15, 2023, 03:18:04 pm »
I don't understand how that is different than a C function with the entire body an inline assembler block.  Do you want the compiler to write the prologue and epilog and handle the ABI?  Or do you want to do all that in assembly?
The precise syntax isn't pinned down yet and when some new stuff like this added one needs to step back and ensure it fits the existing "ethos" of the language, doesn't look like a "bolt on" job as Fred Dibnah would phrase it.
I changed it last night too, so having "procedure" and "function" and "intrinsic" was unworkable because an intrinsic can look like either a proc or a func (returning something) so I made this a new attribute for proc/func and that is neater now:
procedure breakpoint(X) intrinsic(arm) ;
   emit ("bkpt 255");
   emit ("bx lr");
end;
Here the target is an arg to the intrinsic option keyword.
To answer your questions, it looks like a conventional proc/func block but is not, the compiler proper will process an "intrinsic" differently. Basically it will transform the embedded assembler into a byte sequence suitable for the target and will inline that byte block at the point it is referenced. There will likely be restrictions and stuff here but that's academic just now. This now opens the door for writing muti-target intrinsics where the resolution of the specific target is done at compile time, so one could "overload" so to speak.
The key limitation on an intrinsic is that it must be capable of being converted to a machine byte block at compile time so we'll disallow an intrinsic from containing anything other than constant expressions perhaps and using optional arguments, there are several details to work out but this the big picture.
The emit keyword represents the act of "assembly" generation and will allow the language to support this feature independent of potential differing implementations.
The precise nature of the assembly text, its format and so on isn't cast in stone.
Consumer code will reference an intrinsic in the usual way, either via a "call" statement or an operand in a expression, again, in each the reference being literally replaced with the generated machine byte block.
Finally this provides an nice basis for implementing innate, inherent language intrinsic too that are written as part of a compiler implementation, so it brings together the usual idea of a compiler intrinsic and user written embedded assembly code.
« Reply #77 on: February 15, 2023, 03:21:20 pm »
Extended syntax is pretty neat.  It's peculiar, and the documentation isn't exactly exhaustive (I think... the docs are old, somewhat out of date?), and it varies between targets (it follows the traditional asm style(s) of the target), which I'm sure is a pain to keep all the docs updated or whatever.  And of course it's peculiar, it has to encode additional information that asm never otherwise needs; in short, you need to tell the compiler what it can do with it and where/how.
I guess I just wish it weren't so god awful ugly?  Get rid of all the quotes and tabs and newlines, it's all in the source as it is, just consume it verbatim, come on... Anyway.
Like, I finally sat down and crafted this operation last year:
 * Multiplies two 16-bit integers, with rounding, as an intermediate
 * format in 16.16 fixed point, returning the top (integral, 16.0) part.
uint16_t asm_umul16x0p16(uint16_t a, uint16_t b) {
uint16_t acc;
// acc = (((uint32_t)a * (uint32_t)b) + 0x8000ul) >> 16;
__asm__ __volatile__(
"mul %A[argB], %A[argA]\n\t"
"mov r19, r1\n\t"
"mul %B[argB], %B[argA]\n\t"
"movw %A[aAcc], r0\n\t"
"mul %A[argB], %B[argA]\n\t"
"add r19, r0\n\t"
"adc %A[aAcc], r1\n\t"
"eor r18, r18\n\t"
"adc %B[aAcc], r18\n\t"
"mul %B[argB], %A[argA]\n\t"
"adc r19, r0\n\t"
"subi r19, 0x80\n\t"
"sbci %A[aAcc], 0xff\n\t"
"sbci %B[aAcc], 0xff\n\t"
"eor r1, r1\n\t"
: [aAcc] "=&d" (acc)
: [argA] "r" (a), [argB] "r" (b)
: "r18", "r19"
return acc;
On AVR8, there is only 8x8 hardware multiply; this gets used inline well enough (and even 8x16 if you only need the low part), but 16x16 is implemented with a software library (_mulhisi3, etc.)*, the object of which is static, no optimization semantics or anything -- so it's never inlined, and usually makes a mess when patching up to whatever registers the calling function is using.
*Which interestingly enough, don't strictly obey the ABI; they bend it a bit to get better register utilization.  (So, it's not even as bad as it could be.  Mind, not to say what they did is bad in all respects; it's simply a cromulent solution.  Clearly there is room to improve, but it's certainly better than a completely stand-alone function call would be.)  I'm not sure what custom patchups/hacks are internal to GCC to enable this.
So I copied this bit from an earlier pure-asm module, fixed up the register allocations, and used the extended syntax.  This can be inlined properly, and only uses two extra registers (clobber), which are normally free to use (r18-r27 are call-saved registers i.e. any function can use them without having to push/pop).
At least, I think I got the allocations and everything right?  Maybe there's a few edge cases I forgot, but it compiled correctly (output matches on inspection) in the contexts I used it on.  (Yes yes, one can work out all the constraints perfectly, well, must be nice to be able to reason about these things.  I'm a bit hopeless on combinatorial problems like that, I'm afraid.)
So, besides being a bit shorter, it's got no calling overhead (when inlined), and less register pressure overhead, which did nicely for its purpose.  I forget if it fully halved the cycles in the critical path, but it did help out.
This is a very interesting real-world example.
« Reply #78 on: February 15, 2023, 03:32:51 pm »
                    : input-operands
                    : clobbers );
    int64_t result;
                 : "=A" (result)
    return result;
Yes, the register protection is an interesting point, I guess today the coder has to be very careful to save and restore as needed, some machine help here would be nice. I looked at ARM assembly language (Thumb) in some detail and it seems rather straightforward to design a text->binary operation so the actual assembler conversion can readily be coded in a uniform manner in .Net, a small library per target seems very doable.
I did a code generator years ago for X86 (originally 16 bit then later 32 bit) and found that rather interesting work, this is simpler  too, literally just a text conversion and validation, perhaps even doable without a parser, just a simple lexing/regex might even do it.
The operation of the compiler choosing registers is quite interesting but would require the compiler to know the exact nature of the code at ever call site, that's a global analysis, no room for linking in precompiled object files that might also leverage an intrinsic.
I too find the text strings a little unwieldy, so I'm wondering if there might be a abstract grammar that could work for any assembly language, I'd need to some research on this as it could make the code much more readable and open the door to syntax coloring for assembler code. (take a look into language servers, they are very powerful).
The Antlr grammar tools are very powerful too, one can define context aware grammars so that when some thing is recognized, the tokenizer can enter a mode specific to that thing. This literally would enable support for this, that is the compiler when it sees the intrinsic target, can then enter a target specific assembler mode and literally recognize that specific targets assembly syntax, totally eliminating the crude strings.
This is precisely how I'd implement say comments with embedded XML directives like seen in Java or C#, its designed for this kind of parsing.
If you're interested, here are some formal Antlr grammars for a bunch of targets.
« Last Edit: February 15, 2023, 03:39:11 pm by Sherlock Holmes »
Offline DiTBho
« Reply #79 on: February 15, 2023, 03:39:16 pm »
That would be niiice.
GreenHill' CC is a bit different from Gcc, but yup, there is no problem if you segregate assembly-inline into .c files that are somehow known - in your project - as "not pure C" file.
Umm, just make a folder, and put them into it. Don't mix pure C file with impure-because-full-of-assembly-inline-s, that was the point, because it makes the ICE-AI go nut, QA guys angry, etc.
p.s.
the big challenge is ... when you have .o files that come form Haskell sources, and you need to link them with .o files that come from C89 sources and Ada sources.
Haskell + C = difficult (crt0 + crt1 + C-gluecode for IO monads, feasible )
Haskell + C + Ada = more difficult (crt0 + crt1 + ada-RT + C-gluecode for IO monads, more difficult but feasible )
Haskell + Ada = very difficult (ada-RT + ada-gluecode for IO monads?!? not impossible, but toooooo difficult)
Practical real-world experience tends to provide very useful information in the design process.
That's why I suggested OP to get experienced before starting loooong discussions like he did in his topic.
« Reply #80 on: February 15, 2023, 04:02:52 pm »
and
Just, in Avionics you cannot use assembly inline, so when you need machine instruction level, you have to *segregate* code into assembly modules.
Is this a true statement? Ada fully supports embedding assembler code, Ada Core's GNAT Pro fully supports this and is the epitome of mission critical software development tools and languages.
So who said you "cannot use assembly inline" in an avionics setting? what sources do you have for this claim? I do hope you have sufficient experience to discuss this here...
« Last Edit: February 15, 2023, 04:07:56 pm by Sherlock Holmes »
Online Nominal Animal
« Reply #81 on: February 15, 2023, 04:07:50 pm »
It's not "incapable of using", it's "not allowed to use", i.e. due to design guidelines required by the client the software is written for.  Specs like MISRA C.
« Reply #82 on: February 15, 2023, 04:09:40 pm »
That document does not contain the term "assembler" or "assembly" or "inline".
Offline DiTBho
« Reply #83 on: February 15, 2023, 04:17:02 pm »
GNAT is not used in avionics, 99% of times, Green Hills Ada is what I find and use
DO178B-C, with all of its integrated rules.
« Reply #84 on: February 15, 2023, 04:26:31 pm »
Ada and GNAT Pro see a growing usage in high-integrity and safety-certified applications, including commercial aircraft avionics, military systems, air traffic management/control, railroad systems, and medical devices, and in security-sensitive domains such as financial services.
Lockheed Martin Aeronautics, Marietta, Georgia, will be using GNAT Pro to develop the Flight Management System Interface Manager and Radio Control software on the C-130J Super Hercules aircraft.
From Lockheed Martin Selects GNAT Pro for C-130J Software
As I explained to you GNAT (which include assembly embedding capabilities in Ada source code) is used for implementing avionics software, I think that settles the matter.
DO-178B is not a standard, it was in fact a guideline, you should be aware of DO-178C, the devil's in the detail as they say.
But once again, what is actually stipulated in this document that you interpret as a prohibition on the use of assembler or inline assembler?
« Last Edit: February 15, 2023, 04:32:12 pm by Sherlock Holmes »
Offline DiTBho
« Reply #85 on: February 15, 2023, 04:32:42 pm »
Yup,  ... you are allowed to use it, but *ONLY* if the project is level D or E.
Levels A and B are for supersonic aircraft units, war nuclear-powered and Typhoon-class submarines (with titanium hull, and it's an high-grade titanium), high speed trains, etc.
Something similar to DO178B-level-A is what you find in nucler power stations, while Level C can be used in FoM and MotoGP (FoM = Formula One Managment, because it's not so different from their specs), and it's good in automotive.
Level D and E are for domestic gears and common units used in offices and coffee/food machines.
GNU/Linux is classified level E (poor my GNU/Linux router), while "Hardened GNU/Linux"  is classified level D.
(I don't know about OpenBSD ... but I suspect it's level D too)
Level A,B,C also need certified compilers, and certified analysis tools, including certified ICEs and QA code validators.
Offline Siwastaja
« Reply #86 on: February 15, 2023, 04:39:44 pm »
In the end, what the standard actually says, is the standard relevant at all, is the standard wisely chosen, is the design safe at all, does the standard help or hinder, does not matter. All that matters is what the client thinks is important, and what the client thinks the standard says. If DiTBho's work gets accepted by his client, then that's it.
I totally loathe stuff like that and try to avoid such red tape as much as possible, because it almost always results in a system with mediocre safety, for astronomical cost.
« Reply #87 on: February 15, 2023, 04:40:56 pm »
Yet you wrote earlier:
Just, in Avionics you cannot use assembly_inline,
Offline DiTBho
« Reply #88 on: February 15, 2023, 04:58:30 pm »
It's not "a standard". You are asking here for "guidelines", and that's simply the cleanest guideline I have ever experienced in paid job experiences.
« Reply #89 on: February 15, 2023, 05:02:30 pm »
Because DiTBho referred to avionics projects, i.e. level A and B (and not D or E):
Levels A and B are for supersonic aircraft units [...], C can be used in FoM and MotoGP [...] and it's good in automotive.
So, no conflict.  Avionics = A, B; and A, B, C do not allow inline assembly.  What's your problem?
« Last Edit: February 15, 2023, 05:07:32 pm by Nominal Animal »
Offline DiTBho
« Reply #90 on: February 15, 2023, 05:06:35 pm »
cannot = not allowed, if it's a cognitive problem, consider like never written.
« Reply #91 on: February 15, 2023, 05:36:25 pm »
Let me guess, you'll next be sharing your proof that true = false? I can't wait...
 :-DD
« Reply #92 on: February 15, 2023, 05:41:58 pm »
My problem is that the claim that inline assembler is not permitted by some standard or other, in avionics software (in whatever context you care to dream up) remains unsubstantiated, anecdotal, conjecture.
If as has been repeatedly asserted dogmatically, this is true then it should be a simple matter to quote said paragraph here and cite the source, that's my problem.
I am simply asking for evidence, yet none is being presented, so I consider it false, or at best a misinterpretation, unless you can show why I should regard it otherwise.
« Last Edit: February 15, 2023, 05:44:52 pm by Sherlock Holmes »
Offline eutectique
« Reply #93 on: February 15, 2023, 06:01:55 pm »
 :popcorn:
« Reply #94 on: February 15, 2023, 06:04:58 pm »
You mean, the kind where my experience is "anecdotes", but the opinion of a random person whose blog you quote is "proof"?
No, you're playing the kind of social word games that you're used to playing in your workplace, instead of doing actual work.
DiTBho does work for clients that require DO-178 compliance.  They're just telling you what their clients demand.
If you do not trust a single word DiTBho says anyway, why would anyone bother to prove to you anything related to what DiTBho says?
We've tried that with electrodacus and aetherist, and it just does not work, even when we do.  You'll find a way to dodge that and find some other detail to complain about.
If you weren't such a colossal asshole, you would have just said "OK, my mistake; apologies." and moved on.
Instead, you scrambled like crazy to find any detail at Wikipedia or StackOverflow/StackExchange that you could use to take a snipe at DiTBho.
Stop it.  This is a technical forum, not some social media politically-correct snide-fest.  Talk tech, or take a walk.
The following users thanked this post: janoc, Siwastaja, newbrain, JPortici, timenutgoblin, eutectique
Offline Siwastaja
« Reply #95 on: February 15, 2023, 06:29:27 pm »
This is a key point. I sometimes find myself in a situation, on this very forum, where I happen to be one of the maybe top-1000 experts on a subject, and average google result is 99.9% likely a weaker source. Yet, I'm aggressively being asked for sources. In such situations, I simply answer: "source: me". If that does not suffice, then it's the problem of the reader, and they can just f*** o**. The idea that any random blog post, or a hastily written random remark on a Wikipedia page anyone can modify, and no one bothered to properly maintain, is usable as a weapon against true experience from working on or researching a field.
It is very very very difficult to find truly reliable sources. EEVblog forum is a surprisingly high-quality one. But of course, one always needs to apply critical thinking to any source. Just concentrate on the content, not to the fact it was posted on a forum instead of a static website, or Wikipedia.
The following users thanked this post: newbrain, timenutgoblin, Nominal Animal, DiTBho
Online tggzzz
« Reply #96 on: February 15, 2023, 08:19:35 pm »
 :popcorn:
Two phrases spring to mind: "a leopard cannot change its spots", and "so it goes".
The following users thanked this post: JPortici, DiTBho
« Reply #97 on: February 15, 2023, 08:39:10 pm »
Sorry but losing your temper and stamping your feet and making things up when disagreed with won't get you anywhere with me. I questioned the following claim (emphasis mine)
When I did question it (which one has every right to do, question claims made by others) this was the respone:
then I asked:
And then people get all bent out of shape, what is wrong with you? I was just asking a question, where are these prohibition rules? what exactly do they say?
Since when does questioning someone equate to "do not trust a single word" the person says? the melodrama from some here is juvenile. You should be eternally grateful that you didn't take a career in law, you wouldn't last five minutes in a court room with such childish outbursts, your clients would end up suing you!
This is America, we have the right to ask questions, if you don't have an answer that's not my concern.
« Last Edit: February 15, 2023, 08:45:59 pm by Sherlock Holmes »
The following users thanked this post: timenutgoblin
« Reply #98 on: February 15, 2023, 09:06:29 pm »
This is America
Nope.
Dave's site, Dave's forum, Dave's server, so this is Australia, mate.
It does tell a lot about you to assume this is America, though.  Go stick your head somewhere moist.
The following users thanked this post: Siwastaja, newbrain, james_s
« Reply #99 on: February 15, 2023, 09:47:14 pm »
This is America
Nope.
You're all confused again - mate. You even think Finland is in Australia now too, anyway keep trying, I'm sure you'll say something intelligent eventually, might even get on topic at last too if we're lucky or even get the thread locked like last time, you're good at that at least.
« Last Edit: February 15, 2023, 09:54:21 pm by Sherlock Holmes »
