Author Topic: Mega32L External Clock  (Read 3224 times)
Offline bogdan2013Topic starter
  • Always is someone better than you !
« on: February 22, 2013, 02:26:08 pm »
Hello ! I want to put an external crystal oscillator , but I'm not sure how to put it . I need only to put the oscillator terminals to pins 12 and 13 ? It's ok if I put 8 MHz Crystal ?
« Last Edit: February 22, 2013, 02:50:22 pm by bogdan2013 »
Online PA0PBZ
Re: Mega32L External Clock
« Reply #1 on: February 22, 2013, 02:55:47 pm »
An 8 MHz crystal is ok, but have a look at page 26 of this: http://www.atmel.com/Images/doc2503.pdf
You need 2 capacitors to ground also.
« Reply #2 on: February 22, 2013, 03:22:06 pm »
That 2 capacitors in series with pin 12 , 13 with 22 pF values ?
Hmm ... What SUT_CKSEL fuse to put ?
Online PA0PBZ
« Reply #3 on: February 22, 2013, 03:58:14 pm »
It's on the same page.
« Reply #4 on: February 22, 2013, 04:45:39 pm »
Thanks !
