Author Topic: Melody is too long...???  (Read 4964 times)
Offline Tricka90Topic starter
« on: October 03, 2013, 04:38:51 pm »
I'm trying to generate a little melody when my PIC 16F876 turns on. So I wrote in main(), before the while(1) cycle the following note sequence (I use MikroC):
Sound_Play(523,600);
Sound_Play(262,200);
Sound_Play(349,400);
Sound_Play(294,200);
Sound_Play(349,200);
Sound_Play(523,200);
Sound_Play(294,400);
Sound_Play(233,200);
Sound_Play(466,600);
Sound_Play(233,400);
Sound_Play(440,200);
Sound_Play(440,1400);
Delay_ms(1000);
...but it doesn't play the melody just one time! It repeat it forever! Also every repetition it seems like a little bit of code goes on! It looks like a PIC malfunction because if I reduce the lenght of the melody it works PERFECTLY! To be precise, if I stop at note number nine (Sound_Play(349,200);) all it's ok, the melody ends and the program goes on correctly. But if I try to add another note it repeats all the melody forever! Do you know why this happens? Do you know how to work around this strange problem?
Offline c4757p
  • adieu
Re: Melody is too long...???
« Reply #1 on: October 03, 2013, 04:46:23 pm »
Why would you not include the rest of the code?
Offline dannyf
« Reply #2 on: October 03, 2013, 04:47:33 pm »
You didn't read the compiler manual.
Insert a while loop at the end.
« Reply #3 on: October 03, 2013, 05:02:03 pm »
Is very long. If you want to read it I include it:
void main();
 //VARIABLES
int red = 20;
int blue = 20;
int green = 20;
int adc = 0;
int stato = 0;
int mode_change = 0;
int colore = 0;
int clockON = 0;
int pwm_rgb = 0;
int mode = 1;
int j = 0;
int pwm = 0;
int flash = 0;
int lum = 20;
int lum_provv;
int clock = 0;
int intro = 1;
void interrupt()
if (INTCON.TMR0IF)
        if(mode == 5) {
        j++;
        if(j >= flash*30+80)
                            if(pwm == 1)
                                        lum_provv = lum;
                                        lum=0;
                                        pwm = 0;
                            else
                                        lum = lum_provv;
                                        pwm = 1;
                                        j = 0;
        if(pwm_rgb >= 20)
                pwm_rgb = 0;
        else
                 pwm_rgb++;
        if(green >= pwm_rgb && green != 0)
                 PORTB.RB1 = 1;
        else
                  PORTB.RB1 = 0;
        if(red >= pwm_rgb && red != 0)
                 PORTB.RB0 = 1;
        else
                  PORTB.RB0 = 0;
        if(blue >= pwm_rgb && blue != 0)
                 PORTB.RB2 = 1;
        else
                  PORTB.RB2 = 0;
        INTCON.TMR0IF = 0;
void melody()
 Delay_ms(1000);
int RGB(int adc, int i) {
  if(adc >= 210)  {
                if(adc <= 280) { Delay_ms(80); adc = ADC_Read(0); if(adc <= 290 && adc >= 220) {
                               mode_change = 0;
                               stato = 0;
                               { PORTC.RC3 = 0; PORTC.RC4 = 0; PORTC.RC5 = 1; }
                               i = i-1;
                               if(i <= 0){ i = 0;
                                           Sound_Play(659, 20); }
                               Sound_Play(523, 20);
               else            {
                                if(adc >= 940) {
                                                { PORTC.RC3 = 0; PORTC.RC4 = 1; PORTC.RC5 = 0; }
                                                i = i+1;
                                                if(i >= 20){ i = 20; Sound_Play(1319, 20); }
                                                Sound_Play(1046, 20);
                                                Delay_ms(80);
                                if(adc <= 840 && adc >= 320) {
                                      { PORTC.RC3 = 1; PORTC.RC4 = 0; PORTC.RC5 = 0; stato = 1; }
                                      i = i;
if(adc <= 170)
                      { PORTC.RC3 = 0; PORTC.RC4 = 0; PORTC.RC5 = 0; }
                      if(stato == 1)
                                     mode_change++;
                      if(mode_change == 1)
                                           clockON = 1;
                      stato = 0;
                colore = i;
                return(colore);
void main()
ADCON0 = 0;
ADCON1 = 0b00001110;
//TRIS
TRISB = 0;
PORTB = 0;
TRISC = 0;
PORTC = 0;
TRISA = 0b00000001;
PORTA = 0;
PORTA.RA2 = 1;
Sound_Init(&PORTA, 1);
//INTRO MUSIC
melody();
//CCP_PWM (RC2, RC1)
PWM1_Init(5500);
PWM1_Set_Duty(210);
PWM1_Start();
PWM2_Init(1000);
PWM2_Set_Duty(lum*12+10);
PWM2_Start();
//TIMER/INTERRUPT
OPTION_REG = 0b10000010;
INTCON = 0b11100000;
while(1)
 adc = ADC_Read(0);
 if(clockON == 1)
                 clock++;
                 if(clock >= 6500)
                                  if(mode_change >= 2) { if(mode_change <= 4)
                                                if(mode_change == 2) {
        mode++;
        if(mode == 6)
        mode = 1;
                                                if(mode_change == 3 || mode_change == 4)
        mode -= 1;
        if(mode == 0)
        mode = 5;
                                                if(mode == 4)
                                                              PORTB.RB4= 1;
                                                              PORTA.RA5= 0;
                                                              PORTB.RB5= 0;
                                                if(mode == 5)
                                                              PORTA.RA2= 0;
                                                              PORTB.RB4= 0;
                                                              PORTB.RB5= 1;
                                                if(mode == 1)
                                                              PORTA.RA2= 1;
                                                              PORTA.RA3= 0;
                                                              PORTB.RB5= 0;
                                                if(mode == 2)
                                                              PORTA.RA2= 0;
                                                              PORTA.RA3= 1;
                                                              PORTA.RA5= 0;
                                                if(mode == 3)
                                                              PORTA.RA5= 1;
                                                              PORTA.RA3= 0;
                                                              PORTB.RB4= 0;
                                                mode_change = 0;
                                                Delay_ms(50);
                                                Sound_Play(1046, 60);
                                                Delay_ms(15);
                                                Sound_Play(1568, 60);
                                                Delay_ms(15);
                                                Delay_ms(700);
                                  mode_change = 0;
                                  clock = 0;
                                  clockON = 0;
 switch(mode) {
              case 1:
                       RGB(adc, lum);
                       lum = colore;
                       break;
              case 2:
                       RGB(adc, blue);
                       blue = colore;
                       break;
              case 3:
                       RGB(adc, green);
                       green = colore;
                       break;
              case 4:
                       RGB(adc, red);
                       red = colore;
                       break;
              case 5:
                       RGB(adc, flash);
                       flash = colore;
                       break;
No, I didn't found any useful information, I don't even know where to look for information about this issue in the compiler manual...
Ok, I will try adding a while loop which lasts some time
« Reply #4 on: October 03, 2013, 05:23:20 pm »
I tried adding while(1) at the end of the melody and the melody does stop correctly!
But of course I need my program to go on after the melody ends.
So i tried adding a while which lasts some time:
long intro;
while(intro <= 100000) {intro++;}
But as soon as the while cycle ends the melody still repeats forever!
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #5 on: October 03, 2013, 06:51:31 pm »
Sounds a bit like a stack overflow, too little ram?
« Reply #6 on: October 03, 2013, 07:38:12 pm »
When I compile it says RAM is 18% used, ROM 27%. Is it too much?
Offline c4757p
  • adieu
« Reply #7 on: October 03, 2013, 08:32:56 pm »
I don't think it's a stack overflow.
This includes the PEIE bit - peripheral interrupts. There's some code missing (Sound_Init in particular) - make sure you're not setting any interrupts elsewhere, because you aren't clearing them in the handler.
« Reply #8 on: October 03, 2013, 08:43:12 pm »
So should I clear PEIE bit? I use timer0 overflow interrupt in the program as you can see, but the function melody() is called before the all interrupt function is even initialized.
Sound_Init is not missing, it's just before melody() function call, you can see it.
Offline c4757p
  • adieu
« Reply #9 on: October 03, 2013, 08:47:16 pm »
:palm: I missed the order.
Its code is missing, so I don't know what it does. Is it part of a library included with the compiler?
Online mariush
« Reply #10 on: October 03, 2013, 08:49:16 pm »
Maybe you're doing something that resets the microcontroller after song finishes?
Add a sort of counter or some logging through serial port so you see what happens.
Offline dannyf
« Reply #11 on: October 03, 2013, 10:28:07 pm »
It is just one of the prices you pay for using libraries without access to the source code.
Without knowing how the sound functions work, it is not possible to tell where the problems may lie. For example, the sound routines could have used timer0; and your code in the while loop does call the sound function so what you observed could be right.
Without comments, without a methodical approach to debugging, no one can tell for sure.
Offline Psi
« Reply #12 on: October 03, 2013, 10:54:40 pm »
I would just remove sections of code until you find whats causing the problem.
Shouldn't take long.
« Reply #13 on: October 04, 2013, 08:27:21 am »
If it can help you can read all sound function steps for my melody in assembly:
_melody:
;Lampada15.c,89 ::                 void melody()
;Lampada15.c,91 ::                 Sound_Play(523,600);
        MOVLW      11
        MOVWF      FARG_Sound_Play_freq_in_hz+0
        MOVLW      2
        MOVWF      FARG_Sound_Play_freq_in_hz+1
        MOVLW      88
        MOVWF      FARG_Sound_Play_duration_ms+0
        MOVLW      2
        MOVWF      FARG_Sound_Play_duration_ms+1
        CALL       _Sound_Play+0
;Lampada15.c,92 ::                 Sound_Play(262,200);
        MOVLW      6
        MOVLW      1
        MOVLW      200
        CLRF       FARG_Sound_Play_duration_ms+1
        CALL       _Sound_Play+0
;Lampada15.c,93 ::                 Sound_Play(349,400);
        MOVLW      93
        MOVLW      1
        MOVLW      144
        MOVLW      1
        CALL       _Sound_Play+0
;Lampada15.c,94 ::                 Sound_Play(523,600);
        MOVLW      11
        MOVLW      2
        MOVLW      88
        MOVLW      2
        CALL       _Sound_Play+0
;Lampada15.c,95 ::                 Sound_Play(262,200);
        MOVLW      6
        MOVLW      1
        MOVLW      200
        CALL       _Sound_Play+0
;Lampada15.c,96 ::                 Sound_Play(294,200);
        MOVLW      38
        MOVLW      1
        MOVLW      200
        CALL       _Sound_Play+0
;Lampada15.c,97 ::                 Sound_Play(349,200);
        MOVLW      93
        MOVLW      1
        MOVLW      200
        CALL       _Sound_Play+0
;Lampada15.c,98 ::                 Sound_Play(523,200);
        MOVLW      11
        MOVLW      2
        MOVLW      200
        CALL       _Sound_Play+0
;Lampada15.c,99 ::                 Sound_Play(349,200);
        MOVLW      93
        MOVLW      1
        MOVLW      200
        CALL       _Sound_Play+0
;Lampada15.c,100 ::                 Sound_Play(294,400);
        MOVLW      38
        MOVLW      1
        MOVLW      144
        MOVLW      1
        CALL       _Sound_Play+0
;Lampada15.c,101 ::                 Sound_Play(523,600);
        MOVLW      11
        MOVLW      2
        MOVLW      88
        MOVLW      2
        CALL       _Sound_Play+0
;Lampada15.c,102 ::                 Sound_Play(233,200);
        MOVLW      233
        CLRF       FARG_Sound_Play_freq_in_hz+1
        MOVLW      200
        CALL       _Sound_Play+0
;Lampada15.c,103 ::                 Sound_Play(349,400);
        MOVLW      93
        MOVLW      1
        MOVLW      144
        MOVLW      1
        CALL       _Sound_Play+0
;Lampada15.c,104 ::                 Sound_Play(466,600);
        MOVLW      210
        MOVLW      1
        MOVLW      88
        MOVLW      2
        CALL       _Sound_Play+0
;Lampada15.c,105 ::                 Sound_Play(349,200);
        MOVLW      93
        MOVLW      1
        MOVLW      200
        CALL       _Sound_Play+0
;Lampada15.c,106 ::                 Sound_Play(233,400);
        MOVLW      233
        MOVLW      144
        MOVLW      1
        CALL       _Sound_Play+0
;Lampada15.c,107 ::                 Sound_Play(440,200);
        MOVLW      184
        MOVLW      1
        MOVLW      200
        CALL       _Sound_Play+0
;Lampada15.c,108 ::                 Sound_Play(349,200);
        MOVLW      93
        MOVLW      1
        MOVLW      200
        CALL       _Sound_Play+0
;Lampada15.c,109 ::                 Sound_Play(233,400);
        MOVLW      233
        MOVLW      144
        MOVLW      1
        CALL       _Sound_Play+0
;Lampada15.c,110 ::                 Sound_Play(440,1400);
        MOVLW      184
        MOVLW      1
        MOVLW      120
        MOVLW      5
        CALL       _Sound_Play+0
;Lampada15.c,111 ::                 Delay_ms(1000);
        MOVLW      16
        MOVWF      R11+0
        MOVLW      57
        MOVWF      R12+0
        MOVLW      13
        MOVWF      R13+0
L_melody19:
        DECFSZ     R13+0, 1
        GOTO       L_melody19
        DECFSZ     R12+0, 1
        GOTO       L_melody19
        DECFSZ     R11+0, 1
        GOTO       L_melody19
        NOP
        NOP
;Lampada15.c,113 ::                 }
L_end_melody:
        RETURN
; end of _melody
I've tried removing lots of setting like ADCON, the timer0 setting such as opition reg and intcon ecc but still no result.
What would you advise to remove?
The only thing I know is that the problem occurs just when melody is longer than a certain value.
« Reply #14 on: October 04, 2013, 09:07:07 am »
UPDATE: I think I found the reason of the issue.
If I remove WHICHEVER function the melody just repeat once, so the problem is solved!
For example when I remove the two PWM declarations (PWM_Init, PWM_Set_Duty and PWM_Start) the melody infinite repetition doesn't occurs!
So i tried adding those functions later, inside the "while(1)" cycle, but the problem returns...
Maybe is a memory problem, or a CPU issue, I don't know exactly. I think so because WHATEVER big function I remove the problem is solved (for example if I remove the void interrupt() function or the int RGB() function the problem doesn't occur).
But RAM is just 18% used and ROM just 30%, that I can read on the compiler log...
Do you know how I can work around the problem? Maybe with some code simplification (removing useless routines)?
« Reply #15 on: October 04, 2013, 10:06:50 am »
THE PROBLEM IS SOLVED!!!
I found that the problem wasn't occurring when used ROM was less than 2050, so I just correct some "int" with "unsigned short" and do some other little corrections and I manage to make used ROM under 2000, now it works perfectly!!!
But I still have a question: WHY the damn PIC start going crazy if the used ROM is just about 30%??? Do you know why?
Offline Psi
« Reply #16 on: October 04, 2013, 01:13:31 pm »
When you say 'used rom' do you mean program flash or sram?
I've seen some IDE's give the wrong used ram percentage when the MCU in question has a external ram interface.
The IDE seems to assume you're using external ram even when you're not.
So the ram percentage shown is much lower than it really is
Edit: re-reading your post and looking up your MCU i dont think this is your issue.
« Last Edit: October 04, 2013, 01:17:38 pm by Psi »
« Reply #17 on: October 04, 2013, 06:26:03 pm »
The RAM doesn't cause the problem, the ROM it does, or at least that's what I can see from the compiler log.
I mean the program flash memory
Offline PA0PBZ
« Reply #18 on: October 04, 2013, 06:55:30 pm »
According to the datasheet the PIC PIC16F876 has 8K of program memory, so if you are talking HEX 2000 it makes sense since that is 8K. If you are talking decimal 2000 the 30% makes more sense but the problem doesn't.
