Author Topic: Microchip assembly language  (Read 10902 times)
Offline jcaser1948Topic starter
« on: July 27, 2016, 02:54:41 pm »
This code snippet worked perfectly with an older verssion of MPlab, but the new microchip assambler compiler  does not accept it anymore.
The offending part is equ   $    what can I do to substitute this statement with an equivalent one whitout rewriting everything?
Tabla_Mensajes   movwf   PCL      ;Calcula el desplazamiento sobre la tabla
Mens_0      equ   $      ;equ Mens_0 apunta al primer carácter del mensaje 0
      retlw   'H'
      retlw   'o'
      retlw   'l'
      retlw   'a'
      retlw   0x00      ;Ultimo carácter del mensaje 0
Mens_1      equ   $      ;equ Mens_1 apunta al primer carácter del mensaje 1
      retlw   'A'
      retlw   'd'
      retlw   'i'
      retlw   'o'
      retlw   's'
      retlw   0x00      ;Ultimo carácter del mensaje 1
Help would be appreciated, since I an new to the PICS
Offline Andy Watson
Re: Microchip assembly language
« Reply #1 on: July 27, 2016, 03:20:08 pm »
Why do you need the equ $ statement? Mens_0 and Mens_1 should be sufficient labels to identify the start address of the tables.
The following users thanked this post: jcaser1948
Offline StillTrying
  • Country: Broken Britain
« Reply #2 on: July 27, 2016, 03:21:20 pm »
Bit of a guess;
Mens_0      equ   $   % .256  ;equ Mens_0
Online mikerj
« Reply #3 on: July 27, 2016, 03:26:01 pm »
^^^ This.  The assembler knows this is a label for an address, you don't need to add the equ $.
Offline StillTrying
« Reply #4 on: July 27, 2016, 03:33:57 pm »
I'm thinking you need to force it to just have the lower byte of the address.
Offline Andy Watson
« Reply #5 on: July 27, 2016, 04:01:04 pm »
In that case it should be resolved with the LOW() or HIGH() macros when mens_0 is used:
e.g.  movlw LOW(mens_0)
« Reply #6 on: July 27, 2016, 06:17:08 pm »
It compiles I have to test if it works as intended. Thanks
« Reply #7 on: July 27, 2016, 06:20:04 pm »
It does not compile Operand is too complex
Thanks nevertheless
« Reply #8 on: July 27, 2016, 06:22:35 pm »
Yes, Ithink this is the case
Thaks
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #9 on: July 27, 2016, 07:07:24 pm »
Just use normal address labels, like this:-
Tabla_Mensajes:
Mens_0:                ;equ Mens_0 apunta al primer carácter del mensaje 0
      retlw   'H'
      retlw   'o'
      retlw   'l'
      retlw   'a'
Mens_1:                 ;equ Mens_1 apunta al primer carácter del mensaje 1
      retlw   'A'
      retlw   'd'
      retlw   'i'
      retlw   'o'
      retlw   's'
      movlw   Mens_0
      call    Tabla_Mensajes
Online mikerj
« Reply #10 on: July 28, 2016, 08:08:35 am »
Thanks nevertheless
You just said it did compile in your previous post?
« Reply #11 on: July 29, 2016, 11:01:26 am »
Here is the complete program
;   EJERCICIO 18 : LCD con varios mensajes
      List   p=16F870   ;Tipo de procesador
      include   "P16F870.INC"   ;Definiciones de registros internos
Lcd_var      equ   0x20      ;Variables (2) de las rutinas de manejo del LCD
Delay_Cont   equ   0x21      ;Variable para la temporización
Temporal_1   equ   0x22      ;Variable temporal
Temporal_2   equ   0x23      ;Variable temporal
      org   0x00      ;Vector de Reset
      goto   Inicio
      org   0x05      ;Salva vector de interrupción
      include   "lcd_cxx.inc"   ;Incluye las rutinas de manejo del LCD
;Según el valor contenido en el registro W, se devuelve el carácter a visualizar
      retlw   'H'
      retlw   'o'
      retlw   'l'
      retlw   'a'
Mens_1       equ    $ ; Mens_1 apunta al primer carácter del mensaje 1
       retlw   'A'
      retlw   'd'
      retlw   'i'
      retlw   'o'
      retlw   's'
;Delay_var: Esta rutina de propósito general realiza una temporización variable
;entre 50 mS y 12.8". Se emplea un preescaler de 256 y al TMR0 se le carga con 195.
;La velocidad de trabajo es de 4Mhz y por tanto el TMR0 se incrementa cada uS. De
;esta forma, el TMR0 debe contar 195 eventos que, con un preescaler de 256 hace una
;intervalo total de 50000 uS/50 mS (195 * 256). El valor 195 hay que expresarlo
;en Hex. (c3) y como el TMR0 es ascendente habrá que cargar su complemento (3C hex.)
;Dicho intervalo de 50 mS se repite tantes veces como indique la variable "Delay_cont",
;es por ello que el delay mínimo es de 50 mS ("Delay_cont=1) y el máxima de 12.8"
;(Delay_cont=255).
Delay_var:   bcf   INTCON,T0IF   ;Desconecta el flag de rebosamiento
      movlw   0x3c      ;Complemento hex. de 195
      movwf   TMR0      ;carga el TMR0
Intervalo   clrwdt         ;Refrescar el WDT
      btfss   INTCON,T0IF   ;Rebasamiento del TMR0 ??
      goto   Intervalo   ;Todavía no
      decfsz   Delay_Cont,F   ;Decrementa contador de intervalos
      goto   Delay_var   ;Repite el intervalo de 50 mS
      return
;Mensaje: Esta rutina visualiza en el LCD el mensaje cuyo inicio está  indicado en
;el acumulador. El fin de un mensaje se determina mediante el código 0x00
Mensaje         movwf   Temporal_1      ;Salva posición de la tabla
Mensaje_1       movf    Temporal_1,W    ;Recupera posición de la tabla
                call    Tabla_Mensajes  ;Busca caracter de salida
                movwf   Temporal_2      ;Guarda el caracter
                movf    Temporal_2,F
                btfss   STATUS,Z        ;Mira si es el último
                goto    No_es_ultimo
                return
No_es_ultimo    call    LCD_DATO        ;Visualiza en el LCD
                incf    Temporal_1,F    ;Siguiente caracter
                goto    Mensaje_1
Inicio           clrf    PORTB      ;Borra los latch de salida
      bsf   STATUS,RP0   ;Selecciona banco 1
      clrf   TRISB      ;Puerta B se configura como salida
      movlw   b'00011000'
      movwf   TRISA      ;RA0-RA2 salidas, RA3-RA4 entradas
      movlw   b'00000110'
      movwf   ADCON1      ;Configuramos como salidas digitales
      movlw   b'00000111'
      movwf   OPTION_REG   ;Preescaler de 256 para el TMR0
      bcf   STATUS,RP0   ;Selecciona banco 0
      call   LCD_INI      ;Secuencia de inicio del LCD
      movlw   b'00001100'
      call   LCD_REG      ;Envía instrucción: LCD ON, Cursor OFF y blink OFF
Loop      movlw   b'00000001'
      call   LCD_REG      ;Borra LCD y Home (colocar cursor en 1ª posición)
      movlw   Mens_0
      call   Mensaje      ;Visualiza el mensaje 0
      movlw   .20
      movwf   Delay_Cont
      call   Delay_var   ;Temporiza 2 segundos
      movlw   b'00000001'
      movlw   Mens_1
      call   Mensaje      ;Visualiza el mensaje 1
      movlw   .20
      movwf   Delay_Cont
      goto   Loop
      END         ;Fin del programa fuente
And here the include
;                               LCD_CXX.INC
;El conjunto de rutinas que se presentan a continuación permiten realizar las tareas básicas
;de control del módulo de visualización LCD. Este fichero se debe incluir en los futuros
;programas fuente mediante la directiva INCLUDE
#define ENABLE       bsf PORTA,2        ;Activa señal E
#define DISABLE      bcf PORTA,2        ;Desactiva señal E
#define LEER         bsf PORTA,1        ;Pone LCD en Modo RD
#define ESCRIBIR     bcf PORTA,1        ;Pone LCD en Modo WR
#define OFF_COMANDO  bcf PORTA,0        ;Desactiva RS (modo comando)
#define ON_COMANDO   bsf PORTA,0        ;Activa RS (modo dato
      CBLOCK   Lcd_var      ;Inicio de las variables. Será la primera
      Lcd_Temp_1      ;direccón libre disponible
      Lcd_Temp_2
      ENDC
;UP_LCD: Configuración PIC para el LCD.
UP_LCD          bsf     STATUS,RP0      ;Banco 1
                clrf    PORTB           ;RB <0-7> salidas digitales
                movlw   b'00011000'
      movwf   PORTA           ;RA0-RA2 salidas, RA3-RA4 entradas
                bcf     STATUS,RP0      ;Banco 0
                OFF_COMANDO             ;RS=0
                DISABLE                 ;E=0
                return
;LCD_BUSY: Lectura del Flag Busy y la dirección.
LCD_BUSY        LEER                    ;Pone el LCD en Modo RD
                bsf     STATUS,RP0
                movlw   H'FF'
                movwf   PORTB           ;Puerta B como entrada
                bcf     STATUS,RP0      ;Selecciona el banco 0
                ENABLE                  ;Activa el LCD
                nop
LCD_BUSY_1   btfsc   PORTB,7         ;Chequea bit de Busy
                goto    LCD_BUSY_1      ;
                DISABLE                 ;Desactiva LCD
                bsf     STATUS,RP0
                clrf    PORTB           ;Puerta B salida
                bcf     STATUS,RP0
                ESCRIBIR                ;Pone LCD en modo WR
                return
;LCD_E: Pulso de Enable
LCD_E           ENABLE                  ;Activa E
                nop
                DISABLE                 ;Desactiva E
                return
;LCD_DATO: Escritura de datos en DDRAM o CGRAM. Envía el dato presente en el W
LCD_DATO        OFF_COMANDO             ;Desactiva RS (modo comando)
                movwf   PORTB           ;Valor ASCII a sacar por portb
                call    LCD_BUSY        ;Espera a que se libere el LCD
                ON_COMANDO              ;Activa RS (modo dato).
                goto    LCD_E           ;Genera pulso de E
;LCD_REG: Escritura de comandos en el LCD. Envía el comando presente en el W
LCD_REG         OFF_COMANDO             ;Desactiva RS (modo comando)
                movwf   PORTB           ;Código de comando.
                call    LCD_BUSY        ;LCD libre?.
                goto    LCD_E           ;SI.Genera pulso de E.
;LCD_INI: inicialización del LCD enviando el comando "Function Set" 3 veces consecutivas
;con un intervalo de unos 5 mS. El LCD queda borrado y el cursor en la primera posición
LCD_INI      movlw   b'00111000'
      call   LCD_REG      ;Código de instrucción
      call   LCD_DELAY   ;Temporiza
      movlw   b'00111000'
      movlw   b'00111000'
      movlw   b'00000001'     ;Borra LCD y Home.
                call    LCD_REG
                return
;LCD_DELAY: Rutina de temporización de unos 5 mS. Se emplean las variables Lcd_Temp_1
;y LCD_Temp_2 en lugar del TMR0. Este queda libre para las aplicaciones del usuario
LCD_DELAY:   clrwdt
                movlw   .10
                movwf   Lcd_Temp_1
                clrf   Lcd_Temp_2
LCD_DELAY_1:   decfsz   Lcd_Temp_2,F
      goto   LCD_DELAY_1
      decfsz   Lcd_Temp_1,F
      goto   LCD_DELAY_1
      return
            We need the statement     " Mens_0      equ   $   (programcounter)   ;Mens_0 apunta al primer carácter del mensaje 0" in order to adress the lower byte of the list .
Try co compile the program and make (when possible; any suggestios how I couls access the first caracter of the list "Hola"
Thanks
Offline Andy Watson
« Reply #12 on: July 29, 2016, 11:46:03 am »
The example that I gave earlier is apparently the gputil version. The mplab version of the assembler directive is simply "low", e.g.
      movlw   low  Mens_1
See page 40:
http://ww1.microchip.com/downloads/en/DeviceDoc/33014K.pdf
Offline Ata
  • Country: ve
« Reply #13 on: July 29, 2016, 11:59:21 am »
Hi Jcaser..
All you need is to add the following upper case code in your Routine: Mensaje.
And it will work ok.
      MOVLW   LOW(Tabla_mensajes)+1
      SUBWF   Temporal_1,F
                movf    Temporal_2,F
                goto    No_es_ultimo
                return
                goto    Mensaje_1
Offline Ata
  • Country: ve
« Reply #14 on: July 29, 2016, 12:27:34 pm »
Jcaser
I forgot .... Remove the equ $ from Mens_0 and Mens_1 ... Leave them as labels
Mens_0      retlw   'H'
                  retlw   'o'
                  retlw   'l'
                  retlw   'a'
Mens_1       retlw   'A'
                   retlw   'd'
                   retlw   'i'
                   retlw   'o'
                   retlw   's'
Offline Ata
  • Country: ve
« Reply #15 on: July 29, 2016, 12:38:10 pm »
Jcaser..
Another omission... Please correct your Tabla_mensajes as follows:
Tabla_mensajes   ADDWF   PCL
Mens_0   DT   "Hola",00
Mens_1   DT   "Adios",00
Now all will work ok
Offline Ata
  • Country: ve
« Reply #16 on: July 29, 2016, 01:16:54 pm »
Jcaser
Every time you write to PCL ( movwf PCL, addwf PCL, subwf PCL, andwf PCL, etc) you will change PCL's contents but also PCH will take the actual PCLATH value.....
This means that your data-table: Tabla_mensajes  Must be within any 256 boundary program area pointed by the contents of PCLATH.
So you need to include in your start area (INICIO) the following code:
MOVLW   HIGH Tabla_mensajes
MOVWF   PCLATH
This way, when the code ADDWF PCL or MOVWF PCL are executed... PCH will have the corresponding 256 address bank where your Table_mensajes is located.
At power-on-reset  PCLATH=00, If your Tabla_mensajes is not placed on the first 256 byte-address.. It will explain why it did not work at the beginning.
« Reply #17 on: July 29, 2016, 02:48:54 pm »
Dear Alta
I have tried your solution.
The code is like this
      goto   Inicio
     Mens_0    DT   "Hola",00
;(Delay_cont=255).
      return
      SUBWF   Temporal_1,F
                movf    Temporal_2,F
                goto    No_es_ultimo
                return
                goto    Mensaje_1
Inicio
      MOVWF   PCLATH
      movlw   b'00011000'
      movlw   b'00000110'
      movlw   b'00000111'
      movlw   b'00001100'
      movlw   Mens_0
      movlw   .20
      movwf   Delay_Cont
      movlw   b'00000001'
      movlw   Mens_1
      movlw   .20
      movwf   Delay_Cont
      goto   Loop
It still does not compile, probaly because I undertood something wrong in your kindly explanatios. Please check if this code is like what  you intended to convey Gracias
« Reply #18 on: July 29, 2016, 03:07:47 pm »
      movlw   low  Mens_1
See page 40:
Thaks Andy, with your solution it compiles and works fine
 Gracias
Offline Ata
  • Country: ve
« Reply #19 on: July 29, 2016, 04:24:39 pm »
Jcaser..
It doesn't compile because you had duplicated the label: Tabla_mensajes
You have to ways to do it...  Both needs to set PCLATH at the beginnig (Inicio)
If you don't set PCLATH.. I will only work if Table_mensajes is located on the first 256 address of Prog-memory.
MOVWf    PCLATH                            So you can place your Tabla_mensajes  wherever you want
And you don't need: Mens_0  equ $... Also, doing MOVLW LOW Mens_0 is the same like MOVLW Mens_0  Because the MPASM will only take the label's (Mens_0) low byte address by default.
Andy's way: (Better)
Tabla_Mensajes   MOVWF   PCL      ;Calcula el desplazamiento sobre la tabla
Mens_0    DT   "Hola",00
                     movf    Temporal_2,F
                     goto    No_es_ultimo
                     return
                         goto    Mensaje_1
        movlw   low Mens_0
My Way:
Tabla_Mensajes   ADDWF  PCL      ;Calcula el desplazamiento sobre la tabla
Mens_0    DT   "Hola",00
                     SUBWF   Temporal_1,F
                     movf    Temporal_2,F
                     goto    No_es_ultimo
                     return
                         goto    Mensaje_1
        movlw   low Mens_0
« Reply #20 on: July 29, 2016, 05:41:20 pm »
ATA,Thanks for your prompt answer .
With your solutio it does not compile. It says "Symbol not previously defined (Tabla_mensajes)"
here is the program again as I understood your way
      goto   Inicio
Mens_0    DT   "Hola",00
;(Delay_cont=255).
      return
      SUBWF   Temporal_1,F
                movf    Temporal_2,F
                goto    No_es_ultimo
                return
                goto    Mensaje_1
Inicio
      MOVWF   PCLATH
      movlw   b'00011000'
      movlw   b'00000110'
      movlw   b'00000111'
      movlw   b'00001100'
      movlw   low Mens_0
      movlw   .20
      movwf   Delay_Cont
      movlw   b'00000001'
      movlw   low Mens_1
      movlw   .20
      movwf   Delay_Cont
      goto   Loop
You may compile it, if you like;the Include is in my previous post .
Y gracias por todo
Offline Ata
  • Country: ve
« Reply #21 on: July 29, 2016, 10:37:17 pm »
Jcaser .. Please read the compiler errors...
Tabla_mensajes was misspelled as Tabla_Mensajes... That's the error.
Change all to Tabla_mensajes and all errors are gone..
Now its ok..
      goto   Inicio
Tabla_mensajes   ADDWF   PCL,F ;Calcula el desplazamiento sobre la tabla
Mens_0    DT   "Hola",00
      return
      SUBWF   Temporal_1,F
                call    Tabla_mensajes  ;Busca caracter de salida
                movf    Temporal_2,F
                goto    No_es_ultimo
                return
                goto    Mensaje_1
Inicio
      MOVWF   PCLATH
      movlw   b'00011000'
      movlw   b'00000110'
      movlw   b'00000111'
      movlw   b'00001100'
      movlw   low Mens_0
      movlw   .20
      movwf   Delay_Cont
      movlw   b'00000001'
      movlw   low Mens_1
      movlw   .20
      movwf   Delay_Cont
      goto   Loop
« Reply #22 on: July 30, 2016, 12:19:06 pm »
Dear Alta
I have changed Tabla_mensajes as you suggested. I still get the  Error[151]
  C:\USERS\JCASE\MPLABXPROJECTS\LABORA_EJER_18_PIC16F870_ALTA.X\LABORA_EJER_18_PIC16F870.ASM 45 : Operand contains unresolvable labels or is too complex
The offending line is   MOVLW   LOW(Tabla_mensajes)+1  (at pos 45)
sorry for the bothering, but this error nags me. It should compile, but it does not, and de distinctionbetween lower and upper case does not seem to be the problem
Thanks
Offline StillTrying
« Reply #23 on: July 30, 2016, 03:38:41 pm »
Here's 2 variations that should work.
        MOVLW   LOW(Tabla_mensajes + 1 )
        SUBWF   Temporal_1,F
        ADDLW  1
            SUBWF   Temporal_1,F
« Reply #24 on: July 30, 2016, 04:11:27 pm »
This compiles (both solutions). Thank everyone for the help
