Several years back I got more interested in microcontrollers, so I purchased a PIC18 Explorer board.
I used it a total of 2 times, and put it into its original storage. A couple years later, I decide to bring it out again for another project, and I can't program it. Target ID (0) mismatch. All my research online says that the PIC is burned out, bummer.
So I figure I'll start tracing signals from the programmer, since I can verify that works. First signal I try is Vpp. On this board, it routes through a jumper block, and a switch. I trace the Vpp signal to the switch. But no further. Not in any position of the switch. So after two uses of the switch, it's bad.
So I jump out the switch, and lo and behold, it works! Just the damn switch was the problem.
I load up the demo code. And the built in LCD is crapped out. I'm calling it quits on this for tonight.
