Author Topic: Microcontroller 2x(7segment) counter issue  (Read 611 times)
Offline yalectTopic starter
« on: November 24, 2026, 12:38:56 pm »
I have this program of the Microcontroller PIC16F84a but I think there was a probelm with its working, it's a timer based on TMR0 Counter on RA4 Displayed on 2-Digit Multiplexed 7-Segment Display (00-99) when I try to simulate it, it's not giving a good result:  ;====================================================================
; Processor: PIC16F84A
; Function:  TMR0 Counter on RA4 (Rising Edge, 1:1 rate via PSA=1)
;            Displayed on 2-Digit Multiplexed 7-Segment Display (00-99)
        LIST    P=16F84A
        #include <P16F84A.inc>
        __CONFIG _FOSC_XT & _WDTE_OFF & _PWRTE_ON & _CP_OFF
; General Purpose Registers (Bank 0)
        CBLOCK  0x0C
            Tens_Digit          ; Tens place (0-9)
            Ones_Digit          ; Ones place (0-9)
            Temp_Count          ; Working copy for decimal conversion
            Delay_Cnt1          ; Multiplex / debounce delay counter
            Delay_Cnt2
        ENDC
; Reset Vector
        ORG     0x0000
        GOTO    Main
; Lookup Table (Aligned within first 256-word block for PCL safety)
        ORG     0x0100
Get_Seg_Pattern:
        ANDLW   0x0F
        ADDWF   PCL, F
        RETLW   b'00111111'     ; 0
        RETLW   b'00000110'     ; 1
        RETLW   b'01011011'     ; 2
        RETLW   b'01001111'     ; 3
        RETLW   b'01100110'     ; 4
        RETLW   b'01101101'     ; 5
        RETLW   b'01111101'     ; 6
        RETLW   b'00000111'     ; 7
        RETLW   b'01111111'     ; 8
        RETLW   b'01101111'     ; 9
; Main Program
Main:
        BANKSEL TRISA
        MOVLW   b'00010000'     ; RA4 = Input (T0CKI), RA0:RA1 = Outputs
        MOVWF   TRISA
        CLRF    TRISB           ; PORTB (RB0-RB6) = Outputs for 7-segment
        ; OPTION_REG:
        ; bit 7 (NOT_RBPU) = 1 : Disable PORTB weak pull-ups
        ; bit 5 (T0CS)     = 1 : Counter mode on RA4/T0CKI
        ; bit 4 (T0SE)     = 0 : Increment on rising edge
        ; bit 3 (PSA)      = 1 : Prescaler assigned to WDT -> TMR0 is 1:1
        ; bits 2:0         = 000
        MOVLW   b'10101000'
        MOVWF   OPTION_REG
        BANKSEL PORTA
        CLRF    PORTA
        CLRF    PORTB
        CLRF    TMR0
Loop:
        ; Keep 2-digit counter within 00-99 (roll over at 100)
        MOVF    TMR0, W
        SUBLW   .100            ; W = 100 - TMR0
        BTFSS   STATUS, C       ; Skip if TMR0 <= 100
        CLRF    TMR0
        ; Convert TMR0 (0-99) into Tens_Digit and Ones_Digit
        CALL    Split_Digits
        ; --- Display Tens Digit on RA0 ---
        BCF     PORTA, 1        ; Turn off Ones digit first (avoid ghosting)
        CLRF    PORTB
        MOVF    Tens_Digit, W
        CALL    Get_Seg_Pattern
        MOVWF   PORTB
        BSF     PORTA, 0        ; Enable Tens digit
        CALL    Mux_Delay
        ; --- Display Ones Digit on RA1 ---
        BCF     PORTA, 0        ; Turn off Tens digit first (avoid ghosting)
        CLRF    PORTB
        MOVF    Ones_Digit, W
        MOVWF   PORTB
        BSF     PORTA, 1        ; Enable Ones digit
        CALL    Mux_Delay
        GOTO    Loop
; Split_Digits: Converts W (0-99) into Tens_Digit and Ones_Digit
Split_Digits:
        MOVF    TMR0, W
        MOVWF   Temp_Count
        CLRF    Tens_Digit
Div10_Loop:
        MOVLW   .10
        SUBWF   Temp_Count, W   ; W = Temp_Count - 10
        BTFSS   STATUS, C       ; Carry = 1 if Temp_Count >= 10
        GOTO    Div10_Done
        MOVWF   Temp_Count      ; Temp_Count = Temp_Count - 10
        INCF    Tens_Digit, F
        GOTO    Div10_Loop
Div10_Done:
        MOVF    Temp_Count, W
        MOVWF   Ones_Digit
        RETURN
; Mux_Delay: Short delay (~3-5 ms at 4 MHz) for flicker-free display
Mux_Delay:
        MOVLW   .5
        MOVWF   Delay_Cnt1
Outer_Dly:
        MOVLW   .250
        MOVWF   Delay_Cnt2
Inner_Dly:
        NOP
        DECFSZ  Delay_Cnt2, F
        GOTO    Inner_Dly
        DECFSZ  Delay_Cnt1, F
        GOTO    Outer_Dly
        RETURN
        END
- Could you please let me know your comments and notes and corrections or maybe feedback that you see, they will make the counter work or fonction stable?
 Thank you.
« Last Edit: November 25, 2026, 12:44:00 pm by yalect »
Offline westfw
Re: Microcontroller 2x(7segment) counter issue
« Reply #1 on: November 25, 2026, 10:50:07 pm »
“Not good result” how, exactly?
Offline Renate
    • Renate's Android Page
« Reply #2 on: Yesterday at 03:26:21 am »
I don't know PIC from a hole in the ground, but you should fix Get_Seg_Pattern.
If for some reason you get an 0xa to 0xf in there it will run off the end and into Main.
You should add the the hex A-F or at least fudge values for it that you can recognize it visually.
Offline SiliconWizard
« Reply #3 on: Yesterday at 04:50:17 am »
One probable issue is that it doesn't count to 99, but to 100 and so there is likely one step that appears skipped when rolling over.
