Author Topic: Microcontroller and buzzer  (Read 6930 times)
Offline jaRONTopic starter
« on: September 27, 2011, 05:51:22 am »
ok hi I working on a Microcontroller fans controller. It has 14 fans on it and I use 6 Transistors. and 4 Temperature Sensors.  I going to use a BUZZER. so if the temperature get to high it gos off. what i need to know is. can i run the buzzer off the Microcontroller or do I need to put a transistor in it. I use the buzzer obo-1201g-b1
http://www.americor-usa.com/piezo_electric/piezo_print_files/PE%20Page%20041..pdf
Online Psi
Re: Microcontroller and buzzer
« Reply #1 on: September 27, 2011, 06:14:13 am »
I'm not sure if that device generates a tone by itself.
The two terminals may go straight to a pizeo disc. In which case you would need to give it a signal to make sound rather than dc voltage.
If it does produce a sound from DC then that one (obo-1201g-b1) is max 3V 15mA. The micro could supply it directly but if it's a 5V micro you will need a resistor to burn off 2volts.
Something like 2v/0.015A = ~139 ohms
« Last Edit: September 27, 2011, 06:22:36 am by Psi »
Online Zero999
  • 0999
« Reply #2 on: September 27, 2011, 04:19:33 pm »
Those are magnetic sounders not piezo.
The rated current is 30mA which is higher than a typical MCU output can supply so a transistor is required. It needs a squarewave to emit a sound but that's easy to with an MCU or failing that, a couple of transistors. According to the datasheet, the resonant frequency (when it's at its loudest) is 2kHz.
« Last Edit: September 27, 2011, 04:21:32 pm by Hero999 »
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: September 28, 2011, 06:38:50 am »
the safest way is using a driver (transistor). later if you find out the buzzer isnt loud enough, you can simply change it with higher power. and i dont think burdening the mcu to draw much current is a good idea, mcu meant for control, not driver, imho, ymmv.
Online Psi
« Reply #4 on: September 28, 2011, 07:36:10 am »
The one he's talking about (OBO - 1201G-B1) has a max current of 15mA.
15mA is ok for most micros as they're designed to be able to run a 20mA led.
but yeah, a transistor is more future proof and keeps the load off the mcu port.
« Last Edit: September 28, 2011, 07:40:28 am by Psi »
Offline Mat
« Reply #5 on: September 28, 2011, 11:20:41 am »
Isn't it 15mA at the rated voltage of 1.5V?
If it is linear, it would be 30mA at 3V.
Online Zero999
  • 0999
« Reply #6 on: September 29, 2011, 04:24:45 pm »
The DC is 42R so it's a good idea to use a transistor in case the output goes high for too long causing 71mA to flow and damage to the MCU.
Online Psi
« Reply #7 on: October 04, 2011, 05:27:14 am »
hm.. you're right, that datasheet is a bit odd.
the max current isn't actually its max current.
