Author Topic: Microcontroller + BT + Wifi  (Read 2506 times)
Offline docmurTopic starter
« on: November 08, 2015, 06:46:19 pm »
Hey Guys
Does anyone know of a good micro-controller which incorporates both BT and Wifi?  I'm working on a small factor design and if I could isolate the Wifi and BT module into the uC, that would be super helpful.  The max size of the board is 37 mm x 37 mm, hence why everything I can do to save space would help.
Thanks
docmur
Offline zapta
Re: Microcontroller + BT + Wifi
« Reply #1 on: November 08, 2015, 06:48:53 pm »
The ESP32 is supposed to come soon.
« Reply #2 on: November 10, 2015, 12:58:14 am »
Looks likes what I want :), to bad there is no documentation yet.
Offline richardman
« Reply #3 on: November 10, 2015, 03:11:17 am »
Do you need both Wifi and BT in the same chip/module?
// richard http://imagecraft.com/
JumpStart C++ for Cortex (compiler/IDE/debugger): the fastest easiest way to get productive on Cortex-M.
Smart.IO: phone App for embedded systems with no app or wireless coding
