Author Topic: Microcontroller ESD protection  (Read 3802 times)
Offline rocky79Topic starter
« on: September 10, 2014, 06:07:07 pm »
I have been looking for a level 4 ESD pin protection on microcontroller pin( pic16f1503).
The micro digital input pin is used to measure pulses between 50us to 200us.
Do you think a circuit like this would work?
R=500 ohms and
C=0.01uF
VESD=V0=15kv ( Level 4)
Vc=V0(1-e^(-t/RC))
Ic=(V0/R)*e^(-t/RC)
the RC filter will take 1.67uS to charge to 5v however the deadly spikes only last 10’s of nano-seconds.
The initial spike current at t=0  is V0/R=(15kv/500)=30 amps.
In order to conduct this damaging current away from the protected component  I added a TVS diode in parallel with the RC.
What do you think about this TVS from littlefuse part# SD05C it has 5v reverse working voltage and clamp at 14.5v 10amps?
Any other suggestions will be appreciated.
« Last Edit: September 11, 2014, 04:45:30 pm by rocky79 »
Offline thm_w
  • Non-expert
Re: Microcontroller ESD protection
« Reply #1 on: September 11, 2014, 12:28:02 am »
The R needs to be in series with the i/o pin, from what you've drawn thats not correct.
Also I would prefer to use unidirectional TVS. Others may recommend schottky.
http://www.onsemi.com/pub_link/Collateral/AND8424-D.PDF
« Reply #2 on: September 11, 2014, 04:47:05 pm »
Yes, you're right. I have updated the schematic. Also good point about using a uni-directional TVS. Thank you for the advice!
