Author Topic: Microcontroller Voltmeter  (Read 3680 times)
Offline bogdan2013Topic starter
  • Always is someone better than you !
« on: March 30, 2013, 09:17:59 am »
Hello all !
How I can read a external Voltage with my microcontroller (with internal ADC - Mega32) ? I need only basic circuit .
Offline hammil
Re: Microcontroller Voltmeter
« Reply #1 on: March 30, 2013, 09:26:42 am »
Well, that's dead easy. Connect your voltage to the ADC pin, read it in software, display on your 7-segment or LCD module.
However, your range will only be 0 - 5V (or 3.3V). If you go outside it, you will blow up your uC. To avoid this, you'll need to either divide it down (a 1:10 divider will allow you to measure up to 50V, but with decreased precision obviously) or design a proper automatic switching attenuator (which is not easy),
« Reply #2 on: March 30, 2013, 09:59:03 am »
Yep , really easy . I can read the voltage from a pot.  (from 0 -> 5000 mV - 10 bit ADC) , but the problem for me is how to read 12V .
Offline Skimask
« Reply #3 on: March 30, 2013, 10:20:19 am »
And did you read the previous post completely?
Divide the voltage with a V O L T A G E  D I V I D E R
http://lmgtfy.com/?q=voltage+divider
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
« Reply #4 on: March 30, 2013, 11:13:42 am »
Now I understand ! I know about voltage divider . Thanks ! It work fine in ISIS Proteus 7 . I will put in practice .
Offline NiHaoMike
    • Facebook Page
« Reply #5 on: March 30, 2013, 05:16:58 pm »
You'll also want a low pass filter (just add a good amount of capacitance, I've had good luck with 47uF for slow DC measurement channels) and average multiple samples in software for higher effective resolution.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline VanitarNordic
« Reply #6 on: April 02, 2013, 10:06:40 pm »
As other friends said about divider, just put one multi-turn potentiometer on input. You can adjust it easily to earn your linearity parameter, let we name it K.
