Author Topic: Microphone to microcontroller  (Read 4082 times)
Offline Lay-ZTopic starter
« on: December 27, 2022, 10:16:34 am »
Im looking for microphone to microcontroller. It is important that the microphone should have automatic gain. Im looking for microphone similar to Gravity__Analog_Sound_Level_Meter_SKU_SEN0232-DFRobot 1 but more cheaper.
I found only max9814 and sen-12642 but that microphones has no automating changed ranges.
Have you any suggestions? |O
Online SiliconWizard
Re: Microphone to microcontroller
« Reply #1 on: December 27, 2022, 05:56:20 pm »
The MAX9814 has an AGC, what more do you need?
Offline Faranight
  • Country: si
« Reply #2 on: December 28, 2022, 06:18:18 am »
MAX9814 is noisy as hell. I have bad experience with this IC as I tried it with an electret microphone, and the hissing was almost unbearable at higher gains. I then switched to TLV6742 and got complete and utter silence. No autogain though.
Fara-day? Fara-night.
« Reply #3 on: December 28, 2022, 09:23:50 am »
I would like to build a sound level measuring device, something like this
https://svantek.com/
this allows you to measure ambient noise. I simply mean that I would like to get the dB level from the environment as a result. And I found that i don't need AGC. In my electronic collection found sen 12642. Is possible to use it to solution such this?
Offline Kalvin
  • Embedded SW/HW.
« Reply #4 on: December 28, 2022, 09:37:19 am »
If you want to measure the ambient noise level, and relate the results to the human physiological perception, you need A-Weighting filter after microphone to emulate human perception of acoustic energy.
A-Weighting Filter For Audio Measurements:
https://sound-au.com/project17.htm
« Reply #5 on: December 28, 2022, 12:57:29 pm »
Okey thanks for explain. Could you recommend something, cause i can find nothing :/
Offline Brianf
« Reply #6 on: December 28, 2022, 02:57:56 pm »
https://www.ebay.co.uk/itm/175523979279
I believe that it can be found cheaper on Aliexpress.
« Reply #7 on: December 28, 2022, 08:00:11 pm »
If you want to measure sound level, you absolutely don't want to use any kind of automatic gain. So I don't really get your first post.
« Reply #8 on: December 29, 2022, 07:36:52 am »
Thanks Brinaf for help.
SilconWizard, when I wrote the first one post I thought I need AGC, but later it turned out that I doesnt need it, so in the next post I writed that i dont need AGC. Sorry for the confusion guys  :-\
Offline bidrohini
  • Country: bd
« Reply #9 on: December 29, 2022, 02:00:37 pm »
You can check waveshare's sound sensor: https://www.waveshare.com/sound-sensor.htm
It features a microphone and an Onboard audio power amplifier LM386.
Offline Doctorandus_P
« Reply #10 on: January 03, 2023, 04:55:14 am »
 Those aluminimum can based electret's are so last century...
These days microphones look like some 1 by 2mm SMT part and they directly interface digitally with a microcontroller (maybe I2S or something).
I just looked at a random one. The link below is a 3 by 4mm device, so it's a bit bigger then I thought.
https://www.cuidevices.com/product/audio/microphones/mems-microphones/cmm-4030dt-26165-tr
these things are made by the billions. Every phone has one (or maybe more?) of them.
Offline Sacodepatatas
« Reply #11 on: January 04, 2023, 11:23:58 am »
I prefer those little cans because they are more versatile (you can use them with a MCU throught an ADC, or you just use some analog circuitry for conditioning the signal before processing). If you want to make a level meter, you wouldn't like to lose accuracy when converting a linear value from the ADC to a logarithmic value. Hence a propper conditioning of the analog signal (a programmable/selectable decade-gain amplifier) would keep a good compromise of bit accuracy and measure depth.
If you already have a discrete digital signal out of the microphone, then you can't reach such performance.
« Reply #12 on: January 04, 2023, 11:52:56 pm »
Many of the low-cost MEMS microphones have a relatively poor sensitivity, which can make them unsuitable for measuring sound level if you want to be able to go down to 30-35 dB SPL or below.
So sensitivity and frequency response should both be considered before making a choice. MEMS mics with better sensitivity can be very expensive.
Offline spostma
« Reply #13 on: January 06, 2023, 10:18:41 pm »
an inspiring sample project with an ESP32, an I2S microphone and a FFT sound detector:
https://iotassistant.io/esp32/smart-door-bell-noise-meter-using-fft-esp32/
