Author Topic: Microsemi Libero SoC 10 installation problem  (Read 10188 times)
Offline KremmenTopic starter
« on: December 15, 2012, 11:35:28 am »
Looks like the Microsemi FPGA toolchain does not like 64 bit Win7. Installation fails in the beginning because the target directory "is not valid" whatever path i indicate. Even the offered default doesn't work. Quick search from Microsemi failed to enlighten. Has anyone seen this and found a workaround? And yes, i have tried installing in Admin mode and compatibility troubleshooter but no cigar.
« Last Edit: December 15, 2012, 05:17:38 pm by Kremmen »
Nothing sings like a kilovolt.
Dr W. Bishop
Offline workshopper
Re: Microsemi Libero SoC 10 installation problem
« Reply #1 on: January 20, 2016, 04:18:43 pm »
Did you ever find a way around this problem? I'm having the same issue.
Offline seaquester
« Reply #2 on: June 20, 2016, 04:08:43 am »
Have you managed to get around this problem? I'n stuck in exactly the same place (using windows 10). Turning of UAC or switching back to windows 8.1 does not seem to help at all...
Thanks.
Offline dovoto
« Reply #3 on: August 31, 2016, 06:09:55 pm »
Same issue here on windows 10...any ideas?
Offline John_ITIC
  • ITIC Protocol Analyzers
    • International Test Instruments Corporation
« Reply #4 on: August 31, 2016, 06:24:54 pm »
Try to use one of those software tracers that monitors every directory access an application does:
https://www.google.com/?gws_rd=ssl#q=monitor+directory+access+windows
Pocket-Sized USB 2.0 LS/FS/HS Protocol Analyzer Model 1480A with OTG decoding.
Pocket-sized PCI Express 1.1 Protocol Analyzer Model 2500A. 2.5 Gbps with x1, x2 and x4 lane widths.
https://www.internationaltestinstruments.com
Offline rrinker
« Reply #5 on: September 07, 2016, 03:54:10 pm »
 Didn't make the connection at first, but I should walk around the back of the building where I am right now and ask someone - the back half of this customer's building where I am working today is the local offices of Microsemi.
