Author Topic: ModelSim issues... "does not identify a component declaration."  (Read 7043 times)
Offline CM800Topic starter
Hello All,
I'm trying to get ModelSim working. I've got three files (see at the bottom)
the FSM and shift_reg compile fine, however I keep getting the following error:
vcom -work work -2002 -explicit -stats=none {E:/Desktop/ModelSIM Test/serial.vhd}
Model Technology ModelSim ALTERA vcom 10.4d Compiler 2015.12 Dec 30 2015
-- Loading package STANDARD
-- Loading package TEXTIO
-- Loading package std_logic_1164
-- Compiling entity serial
-- Compiling architecture Behaviour of serial
** Error (suppressible): E:/Desktop/ModelSIM Test/serial.vhd(51): (vcom-1141) Identifier "FSM" does not identify a component declaration.
** Error (suppressible): E:/Desktop/ModelSIM Test/serial.vhd(55): (vcom-1141) Identifier "shift_reg" does not identify a component declaration.
** Error (suppressible): E:/Desktop/ModelSIM Test/serial.vhd(58): (vcom-1141) Identifier "shift_reg" does not identify a component declaration.
** Error (suppressible): E:/Desktop/ModelSIM Test/serial.vhd(65): (vcom-1141) Identifier "shift_reg" does not identify a component declaration.
** Error: E:/Desktop/ModelSIM Test/serial.vhd(68): VHDL Compiler exiting
I was wondering if anyone could give me an idea of what I can do to fix this, I've searched around online with little success.
Serial.vhd
LIBRARY ieee;
USE ieee.std_logic_1164.all;
-- This is an example of a serial adder.
ENTITY serial IS
PORT(
A :IN STD_LOGIC_VECTOR(7 DOWNTO 0);
B :IN STD_LOGIC_VECTOR(7 DOWNTO 0);
start :IN STD_LOGIC;
resetn :IN STD_LOGIC;
clock :IN STD_LOGIC;
sum :OUT STD_LOGIC_VECTOR(8 DOWNTO 0)
END serial;
ARCHITECTURE Behaviour OF serial IS
-- Registers
SIGNAL A_reg :STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL B_reg :STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL sum_reg :STD_LOGIC_VECTOR(8 DOWNTO 0);
SIGNAL cin :STD_LOGIC;
-- Wires
SIGNAL reset :STD_LOGIC;
SIGNAL enable :STD_LOGIC;
SIGNAL load :STD_LOGIC;
SIGNAL bit_sum :STD_LOGIC;
SIGNAL bit_carry:STD_LOGIC;
-- Component declarations
BEGIN
PROCESS (clock)
BEGIN
IF clock'EVENT AND clock = '1' THEN
IF (enable = '1') THEN
IF (reset = '1') THEN
cin <= '0';
ELSE
cin <= bit_carry;
END IF;
END IF;
END IF;
END PROCESS;
-- Component instantiations
-- Control FSM
my_control : FSM
PORT MAP(start, clock, resetn, reset, enable, load);
-- Datapath
reg_A :shift_reg
PORT MAP(clock, '0', A, '0', enable, load, A_reg);
reg_B :shift_reg
PORT MAP(clock, '0', B, '0', enable, load, B_reg);
-- a full adder
bit_carry <= (A_reg(0) AND B_reg(0)) OR (A_reg(0) AND cin) OR (B_reg(0) AND cin);
bit_sum <= A_reg(0) XOR B_reg(0) XOR cin;
reg_sum :shift_reg
GENERIC MAP(9)
PORT MAP(clock, reset, B"000000000", bit_sum, enable, '0', sum);
END Behaviour;
FSM.vhd
LIBRARY ieee;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.all;
ENTITY FSM IS
GENERIC(
WAIT_STATE :STD_LOGIC_VECTOR(1 DOWNTO 0) := B"00";
WORK_STATE :STD_LOGIC_VECTOR(1 DOWNTO 0) := B"01";
END_STATE :STD_LOGIC_VECTOR(1 DOWNTO 0) := B"11"
PORT(
reset :BUFFER STD_LOGIC;
enable :BUFFER STD_LOGIC;
load :BUFFER STD_LOGIC
END FSM;
ARCHITECTURE Behaviour OF FSM IS
SIGNAL current_state :STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL next_state :STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL counter :STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
-- next state logic
PROCESS(current_state, start, next_state, counter)
BEGIN
CASE(current_state) IS
WHEN WAIT_STATE =>
IF (start = '1') THEN
next_state <= WORK_STATE;
ELSE
next_state <= WAIT_STATE;
END IF;
WHEN WORK_STATE =>
IF (counter = B"1000") THEN
next_state <= END_STATE;
ELSE
END IF;
WHEN END_STATE =>
IF (start = '0') THEN
ELSE
END IF;
WHEN OTHERS =>
next_state <= '-' & '-'; -- don't care
END CASE;
END PROCESS;
-- state registers and a counter
PROCESS(clock, resetn)
BEGIN
IF (resetn = '0') THEN
current_state <= WAIT_STATE;
counter <= (OTHERS => '0');
ELSIF (clock'EVENT AND clock = '1') THEN
current_state <= next_state;
IF (current_state = WAIT_STATE) THEN
ELSIF (current_state = WORK_STATE) THEN
counter <= counter + '1';
END IF;
END IF;
END PROCESS;
-- Outputs
reset <= '1' WHEN (current_state = WAIT_STATE) AND (start = '1') ELSE '0';
load <= '1' WHEN (current_state = WAIT_STATE) AND (start = '1') ELSE '0';
enable <= '1' WHEN (load = '1') OR (current_state = WORK_STATE) ELSE '0';
END Behaviour;
shift_reg.vhd
LIBRARY ieee;
ENTITY shift_reg IS
GENERIC(
n :INTEGER := 8
PORT(
reset :IN STD_LOGIC;
data :IN STD_LOGIC_VECTOR(n-1 DOWNTO 0);
bit_in :IN STD_LOGIC;
enable :IN STD_LOGIC;
load :IN STD_LOGIC;
q :BUFFER STD_LOGIC_VECTOR(n-1 DOWNTO 0)
END shift_reg;
ARCHITECTURE Behaviour OF shift_reg IS
BEGIN
PROCESS (clock)
BEGIN
q <= (OTHERS => '0');
ELSE
IF (load = '1' ) THEN
q <= data;
ELSE
q(n-2 DOWNTO 0) <= q(n-1 DOWNTO 1);
q(n-1) <= bit_in;
END IF;
END IF;
END IF;
END IF;
END PROCESS;
END Behaviour;
Any support would be greatly appreciated  |O  |O  |O
Offline deebee
Re: ModelSim issues... "does not identify a component declaration."
« Reply #1 on: March 03, 2017, 05:34:20 pm »
Try changing your compile order so serial is after the other two, you can click the right button over the filename to get the menu then select compile->compile order and adjust it in there. Alternatively create component declarations in serial.vhd for the two components that you instanciate.
The following users thanked this post: CM800
Offline deebee
« Reply #2 on: March 03, 2017, 05:47:03 pm »
Just something else to note, if you don't want to use component declarations then you can instance the component with this syntax
my_control : entity work.FSM(Behaviour)
This has been possible since the VHDL 93 standard, although I use component declarations which were mandatory in the VHDL 87 standard (which almost nobody uses anymore) and I am stuck in my ways as an old school vhdl'er!
« Reply #3 on: March 06, 2017, 05:57:10 pm »
Thanks for your help guys, got it working thanks to you :)
