Author Topic: MPLAB X-IDE why y?  (Read 3762 times)
Offline PerranOakTopic starter
MPLAB X-IDE why y?
« on: September 06, 2019, 05:20:14 pm »
Yesterday, I did a little work on my assembly prog in MPLAB and saved the work.
Today, I opened the .asm file and it was blank! This even though it showed as a size of 19k in the directory.
I opened the file in MSWord and examined it and it was actually not blank but full of a weird character - lowercase "y" with two dots over it.
Any idea what on Earth happened and how I can avoid it in future?
Cheers.
You can release yourself but the only way to go is down!
RJD
Offline Sal Ammoniac
Re: MPLAB X-IDE why y?
« Reply #1 on: September 06, 2019, 06:20:28 pm »
Did this happen in MPLAB or MPLAB-X? They are not the same.
"That's not even wrong" -- Wolfgang Pauli
Offline andersm
« Reply #2 on: September 06, 2019, 06:33:11 pm »
Try setting the encoding when opening the file. The "ÿ" character has the character code 0xFF, so I'm guessing it's the LSB of the Unicode byte order mark.
Offline NorthGuy
« Reply #3 on: September 06, 2019, 07:26:03 pm »
Looks like it got corrupted somehow.
Opening it with "Notepad" would be more suitable than MS Word.
You can look at it with a HEX editor to see if some remnants of the text are still there and may be salvaged.
Make backups. Or, better yet, use Git.
« Reply #4 on: September 07, 2019, 09:24:25 am »
Sal Ammoniac: Sorry about the confusion, it's: MPLAB X IDE.
andersm: I'm afraid I don't understand.
NorthGuy: Yes, I looked and the entire file was this character - completely filled. I did a backup of the files (in the project directory) after I'd saved it but of course, this backup had all the "y" fill, darn it! Fortunately, I had copied the file (directly from the running MPLAB X IDE before closing) to play with it and was able to cut/paste it back!  ;D
RJD
Offline MarkF
« Reply #5 on: September 07, 2019, 01:02:19 pm »
I don't see an encoding section when opening a file.
The only see an encoding section during project creation:
829125-0
and in a project properties:
829131-1
« Reply #6 on: September 07, 2019, 01:15:49 pm »
… and I've never changed any of that and the file is 100% full of the "y" character.
RJD
Offline NorthGuy
« Reply #7 on: September 07, 2019, 03:18:34 pm »
Git would let you revert to any version of your file ever committed. It's written by the same guy who wrote Linux.
« Reply #8 on: September 08, 2019, 05:00:28 pm »
Sure that does sound interesting (if it's free) but why the "y"? It's such a mental thing. I can understand a corrupted file that is unreadable or full of random junk but every character space on every line being on character … mad!  :-//
RJD
Online mariush
« Reply #9 on: September 08, 2019, 05:24:55 pm »
Open the file with a hex editor, see for example HxD : https://mh-nexus.de/en/hxd/  or WinHEX : https://www.x-ways.net/winhex/
Those y characters are simply binary data that Notepad can't render with regular font, it's not plain text.
I would guess that MPLAB-X stored the actual assembly code you wrote in a file, and compiled it to binary assembly in the file with the ASM extension and you only copied the already compiled ASM code.
Offline Kilrah
« Reply #10 on: September 08, 2019, 06:19:43 pm »
ÿ is 255 in Unicode. https://www.codetable.net/decimal/255
A blank EEPROM, which is usually full of 0xFF will come up as full of ÿ.
Your file somehow became full of 0xFF.
It could have been a wrong manipulation from you where you compiled something and overwrote your source file with the output file - the file would be the size of the controller's flash and nearly all of it would be unprogrammed, and thus ÿ's.
« Reply #11 on: September 09, 2019, 04:15:51 pm »
Does MPLAB X create listing files for ASM code? Something with a .lst extension perhaps? If so, you may be able to recover your assembly code from that.
« Reply #12 on: September 10, 2019, 12:00:58 pm »
Cheers all. I have recovered the code so that's ok; I just want to ensure it doesn't recur and the best way to do that is to understand it. Ah well.
RJD
