Author Topic: mpu6050 interrupt help ?  (Read 4993 times)
Offline koray692Topic starter
« on: February 19, 2016, 02:39:47 pm »
hello friend ..I want to take data in period 10 ms from the  sensor I check the register map I didnt understand..Sensor has the pin "int" how can I use this pin...which register arrange I am some confused...
« Last Edit: February 19, 2016, 03:08:12 pm by koray692 »
Offline Skimask
Re: mpu6050 interrupt help ?
« Reply #1 on: February 19, 2016, 03:03:53 pm »
What?
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
« Reply #2 on: February 19, 2016, 03:09:12 pm »
I arrange it :)  it put "?" insted of "I"
Offline Skimask
« Reply #3 on: February 19, 2016, 03:16:57 pm »
Still doesn't make sense.
I turned it on.
« Reply #4 on: February 19, 2016, 03:29:57 pm »
how can I get sample from the mpu6050 sensor at every 10 ms ?(by using interrupt)
Offline ChristofferB
  • Chemistry phd at long last!
    • My channel:
« Reply #5 on: February 20, 2016, 12:56:04 pm »
That sounds kinda contradictory. Getting data every time interval sounds like polling, and getting data via interrupt is based on an event. Though I haven't worked with that part, so I could be wrong.
--Christoffer
--Chris //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline mikerj
« Reply #6 on: February 20, 2016, 06:20:11 pm »
--Christoffer
It's quite possible to poll a device using a timer interrupt.
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #7 on: February 20, 2016, 09:26:37 pm »
The MPU6050 outputs data at 1kHz (when the digital low pass filter is enabled). To make it send data slower you write a division ratio to the SMPLRT_DIV register.
Sample Rate = Gyroscope Output Rate / (1 + SMPLRT_DIV)
To enable the Data Ready interrupt you must set bit 0 (DATA_RDY_EN) in the INT_ENABLE register. You may also need to modify other bits in this register, depending on what type of interrupt signal you want.
